6 members (walterhvogel, klhansen, Jman, Tom McGrath, UtahYork, Materman), 88 guests, and 2 robots.
Topics128,035
Posts1,055,557
#1411226 05/24/2021 10:59 PM
Does anyone know of a rebuild kit for the gears in the windshield crank on a 37 chevy??
I am not aware of a do-it-yourself rebuild kit. Based on my experience with my '42 and '37, as the mechanism wears, the steel axle of the wheel that moves the tongue wallows out the hole in the aluminum body. This causes the gears to not mesh properly and causes wear of the gears. To restore the assembly you have to start with fixing that wallowed out hole in the body.
A friend help fix the mechanism of my '42 by making an aluminum bushing for the axle and then milling a hole for the bushing in the body. We couldn't do much for the wear on the gears but it re-aligned the gears so they now mesh properly and the crank functions much better. There is still a little slop in the crank due to the previous wear of the gears.
If you search the internet you will find restored assemblies on Ebay, as well as someone who has made new aluminum castings of the body. I don't know if either one makes new gear sets.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
It is here somewhere.....or over on the VCCA site of a fellow who is reproducing them. I may have seen the ad in the VCCA magazine with the info......but pricey. I think they are asking around 425 for a complete new unit.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Moderated by  ndkid275, Phak1
