Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, cmayna), 226 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#14099 12/04/2003 5:58 PM
I have a 51 235 that I have removed from my 52 1/2T. I am going to rebabbit it and reinstall. While it is on the stand is there any way I can tell if the block is cracked? What normally cracks? The piston sleeves or the water jacket? I see no indication of cracks on the outside of the block. Thx.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#14100 12/04/2003 6:24 PM
I
Junior Member
Junior Member
I Offline
These engines tended to crack on the outside on the drivers side just about in the center.Dont recall any other places much.. the heads cracked on both sides from freezing...but also cracked around the exhaust seats sometimes....One thing to look for is one or more cylinders cleaner from carbon than the others...water will wash out carbon.....That might indicate a crack in the cylinder head.... cool
If all the cylinders ain't in a line it ain't cuttin it..
#14101 12/04/2003 6:37 PM
If you're going to rebuild this engine, I strongly suggest you bring it to a reputable machine shop that will magnaflux the engine block and cylinder head. These blocks can also exhibit cracks in the main bearing caps or webs from heavy use, bearing failure, bolt stresses or improper handling of the block. The older engines such as yours that may have been operated without antifreeze can also rust out between the bottom of the water jacket and the crankcase.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#14102 12/08/2003 6:11 AM
Also, I would replace the babbitt bearings with insert bearings... a lot quieter.
#14104 12/08/2003 5:36 PM
I replaced the Babbitt bearings in my 235 with insert bearings and I know of a lot others that have done it. It can be done with no problem.
#14105 12/08/2003 6:52 PM
I had my 216 rods machined to take the insert bearings. The new inserts have a slotted hole where the dipper mounts. The McQuay Norris brand of inserts have the slotted hole centered in the rod cap, which is actually not optimum. The correct location is located off center. I don't think they would do any harm but I used a different brand.
1951 1 Ton Completed
#14106 12/08/2003 9:05 PM
I can vouch for what inlineal says...I had a 216 in a '51 chevy car and that is exactly where my block cracked after leaving the engine full of water through the winter.
