0 members (), 139 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
Hey guys new member here, I have a 57 1 ton dually that has 19.5's on the rear but 16.5's on the front. Was this a factory option? Anyone able to point me in the right direction for 2 matching 19.5's for the front? Thanks guys![img]https://www.stovebolt.com/ubbthread...84679BF-ECC6-48F1-AC97-589EF5611926.jpeg[/img]
1957 Chevy 3800
AD Addict & Tinkerer
Have you tried searching in the forums? I looked and here’s one where they converted to 19.5’s as an example. https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1347038/new-tires-and-rims.html
Phil
Project Journals
Stovebolt Gallery Forum
Thank you that is exactly the look I’m going for I did search for info regarding the different rim sizes but came up empty
1957 Chevy 3800
Crusing in the Passing Lane
I don’t think 16.5’s ever came on ‘57’s, or anything else for that matter.
Ed
Ed
I had a '72 K10 Chevy that had 16.5's on it. They were 6-lug. I believe the '84 GMC 3/4 ton I had also had 16.5's but they were of course 8-lug.
Offline
Offline
It's likely that someone found a good pair of tire on a pair of rims that were direct bolt-on. Nothing new on the farm!
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
I think I have one 19.5 wheel for eight bolt hub. I'll check.
Mike
573 592 1991 work hours
573 864 6539 mobile
1936 1-1/2 Ton (RD) Stake Body Original
I have parted several of the duallys like yours. Many had the 19.5 like you had in the rear. I believe the fronts are from a different vehicle.
ppp
I found some 16.5’s with 10 on 7.25” bolt pattern, was looking for 19.5’s, didn’t check.
Ed
Moderator
Moderator
2 Offline
I looked yesterday and my 57 GMC one ton dually has 18 inch split rims all around.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Hit the nail on the head!
16.5" will fit front but need larger diameter inside the wheels on the rear to fit over the large diameter drums. Have seen newer dual wheel turned out & run as a single on the rear, some real creative folks!
BC
1960 C60 pasture art
Yeah that makes sense about using what you have around the farm! If I can’t find fronts I’ll go aftermarket all the way around but I’d like to stay as original as possible. Thanks for all the input guys!
1957 Chevy 3800
I checked and have two 55-59 Chevy 1 ton duallys . Both have the original 19.5 original tubeless duallys.
ppp
Moderated by  Dusty53
