Hello all, been reading this forum for a while, thought it was time to finally get involved. Just purchased my second stovebolt! Both are "Big Bolts". A couple years ago I picked up my first, 1961 Chevy (Viking?) C60 Wayne School bus, we are going to cover it into our family RV. It's going to take some doing, but there won't be one like it.
A few days ago I found my second. A 1947 Chevy 2 Ton. A legitimate "field find". The owner said it came with ranch. He had never seen it move. Been parked for the last 3 decades. He has no idea where the title is, so it will be bill of sale only. That's not too big of an issue here in Montana. We agreed on a price and I set off to tinkering. Had it running in about 2 hours. I need to get some air in a couple tires and refill and bleed the brakes. Going to attempt to drive it home on the backroads (about 80 miles).
Looking forward to getting her home! I'll update by making some new threads over in the Big Bolts section!
Last edited by Peggy M; 01/17/20241:06 AM. Reason: Think I attached the pics directly
Great truck. Most of the field finds around here have the windows shot out at least. Looks like a hay truck to me also. I like the way the tire chains are stored. Good luck on your 80 mile break-in trip.
Looks like it might have had a hydraulic winch possibly for loading something judging by the rollers on the back of the bed and the hydraulic controls on the steering column. Probably PTO driven, with control levers just in front of the seat. Maybe a tilt bed? Interesting truck for sure. Good luck on that trip. Check out those old tires closely. You don't want to have a blowout.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
My Dad was a carpenter and the local lumber store used a truck with a bed just like that. No strap on fork lifts back then. The bed would tilt and the rollers would allow the entire banded load to be slid off the bed to unload.
I agree with klhansen about the extra hay on the rack!
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Welcome to Stovebolt. Hey hey hey, what a treasure. Thanks for the pictures and be careful, very careful getting it home. See you around the garage forums.
Thanks for the info. And yes, we'll be very careful diving home. We're going all backroads to limit the traffic exposure. If it can't be driven safely, I'll have to tow it. Figured out the picture attachments. Can I still link photos using an address? Or are we suppose to just use the attachments?
As per requested, here are some bus pics. The story is that this bus was previously converted into a makeshift camper. We got it running and drive it about 60 miles home. You literally cannot wipe the smile off your face while driving one of these!
We have our own plans to convert it so step one was gut it completely. We were in the process of moving and it made for a great moving truck! Now it sits, waiting it's turn. It is currently referred to as "the hardware store" it's got a little of everything inside.
Indeed it does! That bus will do 50-55 mph. When we start our conversion the bus will become a diesel. Mainly for safe cruising down the highways. It's quite possible that the new-to-me 47' will end up with that 261.
