1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I've never done this before. I have the block stripped of pretty much everything including the head. I also have the hood and radiator removed. My next step is to rent an engine lift and pull it out. How do I rig the lift to the block? Should I put the head back on? As usual, all help and guidance is appreciated! And I love pictures 😠| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Don't put the head back on. You can either use a couple of eye bolts or just some spacer washers and a chain with 2 bolts, make sure you have a nice large loop in the chain or you stress things too much. If you were close I'd help.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Is the transmission still attached to the engine? You will need to unbolt the transmission from the bell housing and either remove if or at least slide it back a little and support it. 235's have hidden bellhousing to block bolts behind the flywheel so the simplest way to remove the engine is to do it with the bellhousing, flywheel, and clutch still attached, by removing the bellhousing motor mounts. A 3 speed transmission can stay attached to the engine and the whole assembly can be removed together. Removing an engine with the 4 speed attached is much more difficult due to its size and weight, so it's better to unbolt it before pulling the engine. Jerry
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | I say remove the transmission. Just easier to get it all out then. Unless you plan on removing the whole front clip and remove straight out the front. Don't try to remove the flywheel housing, the clutch and flywheel need to come off first to get to the inside bolts.
