Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Guitplayer, KEVINSKI, SmalltownTRKGuy, Otto Skorzeny, UnclePaddy, TGP), 134 guests, and 6 robots.
Topics128,281
Posts1,058,461
Members48,490
I've never done this before. I have the block stripped of pretty much everything including the head. I also have the hood and radiator removed. My next step is to rent an engine lift and pull it out. How do I rig the lift to the block? Should I put the head back on? As usual, all help and guidance is appreciated! And I love pictures 😁
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Don't put the head back on. You can either use a couple of eye bolts or just some spacer washers and a chain with 2 bolts, make sure you have a nice large loop in the chain or you stress things too much.
If you were close I'd help.
Is the transmission still attached to the engine? You will need to unbolt the transmission from the bell housing and either remove if or at least slide it back a little and support it. 235's have hidden bellhousing to block bolts behind the flywheel so the simplest way to remove the engine is to do it with the bellhousing, flywheel, and clutch still attached, by removing the bellhousing motor mounts. A 3 speed transmission can stay attached to the engine and the whole assembly can be removed together. Removing an engine with the 4 speed attached is much more difficult due to its size and weight, so it's better to unbolt it before pulling the engine.
I say remove the transmission. Just easier to get it all out then. Unless you plan on removing the whole front clip and remove straight out the front. Don't try to remove the flywheel housing, the clutch and flywheel need to come off first to get to the inside bolts.
