3 members (hardshell, FishinToms53, lumbersawyer), 45 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#13967 02/15/2004 4:43 AM
Hey Bolters,
Since the engine and driveline turn the tires I figure its ok to ask this here. My 52, 1/2t. has 600-16 tires that need replacing. 16 inch tire are really up there in price. Can you guys tell me what your running if your not with the standard 600-16s? I have a 235, so I wouldn't think that power for alittle wider tire would be a problem. I do want to stick with mt standard rims. What do you think?
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#13968 02/15/2004 9:24 PM
Glenn,
Greetings from the NORTH St. Paul 'burbs! I switched to a 15 inch tire to stay more narrow and cost effective. Sams Club (35e) had an 85 width 16 that tempted me pretty hard. It was narrower than other 16's available, which is a concern if you don't want to rub on the body or switch rims. They are designed for the modern dually trucks but could work on the chevy. The height seemed close to a 6-50 and would be better on the highway gearing than a lower to mid 15 like I got. They're not cheap though, at 75-85 each. If you do want to switch to 15's I've got a local tip to consider.
How far are you on yours? I'd be gald to have local guys to swap notes with...
#13969 02/16/2004 7:32 PM
I bought 2 16" Power Kings at Pomps for about 70 each. They were 7 or 7.5 wide and 31" tall bias. They also offer a snow that is 33" tall. Very heavy duty. - Scott - Wisconsin
55 1st Chev.
#13970 02/16/2004 10:45 PM
Jake,
If you know of any good events, swap meets, etc in the metro area, keep us in the know. I have been out of the old truck scene for awhile and am trying to figure out where to go for parts etc.
From South of the River....
#13971 02/17/2004 1:12 AM
Will do! I learned a nasty lesson last fall at the end of September meet. I'll update later. There are a bunch of them as the summer rolls on. Are you a member of MSRA? They put out a real good list too.
#13972 02/18/2004 5:25 AM
Junior Member
Junior Member
I found a set of original 16" rims for my '54 3100. These wheels measure 4" wide.
I use new 215/85R 16 D range tires. Most tire stores have these. The manufacturer recommends no narrower than 5.5" rims, but these tires have so much sidewall, they squeeze right down, look and drive just fine.
I have about 2500 miles on mine, would do it again. The tall tires also help overcome the 411 rear gear.
