3 members (TUTS 59, Jon G, Joe H), 97 guests, and 3 robots.
Topics128,026
Posts1,055,402
Members48,422
#1396686 02/10/2021 11:11 PM
Just stopped in to say hello. My name is Rob and I'm from the cold north. Edmonton, Alberta Canada. I have just taken on a unfinished project from my dad's estate.
It is a 1952 GMC 9300 Deluxe cab 5 window 1/2 Ton. It has I believe a 235 in it, with a 3 on the tree. I've been dealing with some issues, like wrong bolts, screws, and etc. Will try and post pictures soon.
Also, spray foam everywhere, as in behind the fuel tank and in the cab corners, my father had it painted just before he passed, close to the original blue that it had come in.
It has also been converted to a 12 volt system.
Thank you for adding me. Need to learn lot's, has been a while since working on automotive.
!952 9300 GMC
Badger Bob #1396722 02/11/2021 2:54 AM
Bob, Welcome to the Stovebolt. Consider yourself at home. Lots of garage forums to ask your questions and guys here that can answer them. Sounds like your father gave you a good start on the restoration.
.......see you around the garage forums.
Badger Bob #1396724 02/11/2021 3:02 AM
Welcome to the Stovebolt madness. There is no cure! shake
Badger Bob #1396729 02/11/2021 3:52 AM
Welcome to the 'bolt. Please post some pix of the truck when you get a chance.
You might want to leave some of your fathers "work" as a reminder of him. (I am leaving the dent in the grill of the vehicle my father willed me along with some Arizona mud that splashed on it while he was bombing around the wilderness).
Another quality post.
Real Trucks Rattle
Badger Bob #1396741 02/11/2021 12:04 PM
Leo Offline
Moderator
Moderator
Welcome to the site Rob. Hope your shop is heated, heard about that -44 weather you had a few days ago. You must have the Canadian version of GMC, Chevy powered. Good luck with it and be sure to ask if you run stuck.
Leo
Badger Bob #1396752 02/11/2021 1:58 PM
AD Addict & Tinkerer
Welcome to the “Bolt”! Sorry for your loss. It sounds like you have a nice project. You’ll be thinking of Dad every time you work on it. You have the GMC version of my ‘52 Chevy 3100. I also have a 235 in mine, although a transplant from a ‘59. Don’t hesitate to ask for help. The guys/gals on this forum are great, extremely knowledgeable and willing to help.
Post some pictures!
Phil
Project Journals
Stovebolt Gallery Forum
Badger Bob #1396796 02/11/2021 7:41 PM
Thanks for all the welcome.
!952 9300 GMC
Badger Bob #1396903 02/12/2021 4:42 AM
Nice rig!
BC
1960 C60 pasture art
Badger Bob #1397474 02/15/2021 11:20 PM
Thanks BC59. Unfortunately it didn't come cheap, cause my father and I had talked, and he thought I was was going to customize it. Well in order to keep siblings happy I paid a pretty penny for it. But not close to appraised value. It is a driver not a concourse build by any means. But now it's mine and I will keep my father's wish. It will not become a restomod. The next one well!!!!! We're not sure. LOL. I would like for it to look pristine as she looks with proper hardware. The body shop we had used before his passing said that we should use 1" wood well that looked like a@@ and I had decided to have it shaved down. Well that didn't work out well for me either. So new Hickory is being planed and sanded and finished as we speak, on this forum.
Also he had bear claws added to the doors, for ease of closure as he was aging. He also had the box side ends closed up as well as the stake pockets.
I also noticed a light under the dash, what the heck is that. Then I turned the key on and it lit up. I guess so he wouldn't forget the key was on. LOL
Funny little things you find. OP had put the starter button in the dash where the cigarette lighter would of been.
!952 9300 GMC
Badger Bob #1397507 02/16/2021 1:39 AM
Badger Bob said "I also noticed a light under the dash, what the heck is that. Then I turned the key on and it lit up. I guess so he wouldn't forget the key was on. LOL"
If the trucks running a alternator the light could be there to excite the alternator. Once the truck starts up the light should go out and the alternator starts charging, regardless of engine rpm.
RonR
RonR
1970 340 Duster
1964 CJ5
Badger Bob #1397520 02/16/2021 4:46 AM
Fox Offline
Agreed. Nice unit and story. Summer is coming! I run into the city from time to time with my old GMC. Welcome to the site.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
