0 members (),
84
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | I passed on the smaller rusty 1958 3800 truck and went with this truck. This truck will be a food truck with the foodservice going on top of the flatbed. Weight in the bed will be 1-2 tons. I am trying to decide between a 454 or LS 6.0. I have other GM trucks/cars/boats with either LS/SBC/Detroit Diesel. This truck will need to run on e85 so LS swap with a flex-fuel sensor or 454 with bumped up compression and EFI. The seller said that this truck has a 6.72 gear. It is a 2-speed axle. Straight 6 with 4 speed that is coming out if anyone wants one. 1958 Chevy Viking 6100 Pictures
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Your stock 2-speed rear will have 6.40/8.72 to 1 ratio. It might be easier to move the cab to a modern chassis that's already got the engine, trans and rear you want. You would also get newer rims/tires. Maybe a Kodiak...measure the front axle and start looking... Just a thought... Mike B  | | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | I found these 19.5 x 6x8.75 wheels from a modern Isuzu. Would this fit and replace my split rim tube wheels? The Isuzu WheelsMy Current Wheels
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | your Viking has 22.5 wheels, 19.5 wheels will look small in the opening. If you look around, you should be able to find some 22.5 wheels used from a moving van or some other truck. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If economy is of any concern then the LS is the hands down choice. Torque is about the same for both and the LS has more horsepower. If you don't already have an engine you might check out the LQ which I believe is a truck version of the LS. I have no experience with E85 but on the 10% alcohol the LS gets right at double the mileage of a 454.
Evan
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | That cross member might work...depending on what transmission are you going to use? You also might have to remove the existing bell housing cross member and then fabricate a new one as that cross member also stabilizes the frame at the spring hanger. The easiest swap might be a 350 SBC and keep the existing transmission...all you would need would be a V8 bell housing, V8 throttle linkage and V8 front motor mounts. The SBC can handle higher rpm so the truck can run faster. Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I used one of those for the engine on my 59 Suburban, along with the factory V-8 bellhousing and rear mounts. It worked fine but, I should have just bought the front V-8 mounts and been done with it. If your V-8 does not have holes in the front for the original style mounts, then this is a great alternative. | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | I used one of those for the engine on my 59 Suburban, along with the factory V-8 bellhousing and rear mounts. It worked fine but, I should have just bought the front V-8 mounts and been done with it. If your V-8 does not have holes in the front for the original style mounts, then this is a great alternative. Got a question, did you have to re-route the brake lines after installing that crossmember? From what I've seen and read, the brackets for that crossmember come close to where the lines run through the frame rails. | | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | I got an LS (LQ4 6.0) and 4L80E for $575 along with 6 original 22.5 Tubeless Budd wheels. I am waiting on the tubular LS cross member kit to come in. 6.0 LS Engine Chevy Viking Swap22.5 Tubeless Budd Wheels - 1958 OriginalsOnce I get the engine and transmission in, I'll be able to add modern 22.5 tires and this truck will be good to drive anywhere.
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | | | | | | Joined: Nov 2019 Posts: 18 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 18 | | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Feb 2020 Posts: 5 New Guy | | New Guy Joined: Feb 2020 Posts: 5 | I also have a 58 Viking and plan of driving fairly regularly. What do all of you Big Bolters do for insurance? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Shop Hagerty as well, they are an ATHS sponsor now insuring antique big rigs. Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I just go a note from Gulfway, they are using Hagerty now.
Ed
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | J Apache Nice truck those Apache's were tough,Once built a 500 gallon spray truck for row crop work if you didn't let out of it would go thru about 8 inches of clay mud in a wet place with a full load of corn spray on. Those tall narrow wheels and tires worked. 327 with sm 420. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | J Apache just replied to you-poof it disappeared will re- appear now majic ??? | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | I passed on the smaller rusty 1958 3800 truck and went with this truck. This truck will be a food truck with the foodservice going on top of the flatbed. Weight in the bed will be 1-2 tons. I am trying to decide between a 454 or LS 6.0. I have other GM trucks/cars/boats with either LS/SBC/Detroit Diesel. This truck will need to run on e85 so LS swap with a flex-fuel sensor or 454 with bumped up compression and EFI. The seller said that this truck has a 6.72 gear. It is a 2-speed axle. Straight 6 with 4 speed that is coming out if anyone wants one. 1958 Chevy Viking 6100 Pictures | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | J Apache Dont know what I done there-not a computer whiz !! Sorry | | |
