2 members (latroca52, 1 invisible), 131 guests, and 3 robots.
Topics128,196
Posts1,057,388
Members48,471
I passed on the smaller rusty 1958 3800 truck and went with this truck. This truck will be a food truck with the foodservice going on top of the flatbed. Weight in the bed will be 1-2 tons. I am trying to decide between a 454 or LS 6.0. I have other GM trucks/cars/boats with either LS/SBC/Detroit Diesel. This truck will need to run on e85 so LS swap with a flex-fuel sensor or 454 with bumped up compression and EFI. The seller said that this truck has a 6.72 gear. It is a 2-speed axle. Straight 6 with 4 speed that is coming out if anyone wants one.
1958 Chevy Viking 6100 Pictures
Your stock 2-speed rear will have 6.40/8.72 to 1 ratio.
It might be easier to move the cab to a modern chassis that's already got the engine, trans and rear you want. You would also get newer rims/tires. Maybe a Kodiak...measure the front axle and start looking...
Just a thought...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I found these 19.5 x 6x8.75 wheels from a modern Isuzu. Would this fit and replace my split rim tube wheels?
The Isuzu Wheels
My Current Wheels
Big Bolt Forum Moderator
your Viking has 22.5 wheels, 19.5 wheels will look small in the opening. If you look around, you should be able to find some 22.5 wheels used from a moving van or some other truck.
Mike
If economy is of any concern then the LS is the hands down choice. Torque is about the same for both and the LS has more horsepower. If you don't already have an engine you might check out the LQ which I believe is a truck version of the LS. I have no experience with E85 but on the 10% alcohol the LS gets right at double the mileage of a 454.
Evan
I found original 22.5 budd tubeless wheels. I want to use this V8 Crossmember. In the photo it looks like the engine cross memeber mounts behind the factory engine cross member? Has anyone ever used this?
https://www.performanceonline.com/1...ransmission-crossmember-kit-with-mounts/
That cross member might work...depending on what transmission are you going to use? You also might have to remove the existing bell housing cross member and then fabricate a new one as that cross member also stabilizes the frame at the spring hanger.
The easiest swap might be a 350 SBC and keep the existing transmission...all you would need would be a V8 bell housing, V8 throttle linkage and V8 front motor mounts. The SBC can handle higher rpm so the truck can run faster.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I used one of those for the engine on my 59 Suburban, along with the factory V-8 bellhousing and rear mounts. It worked fine but, I should have just bought the front V-8 mounts and been done with it. If your V-8 does not have holes in the front for the original style mounts, then this is a great alternative.
Mike
Rustbucket Ranch
Rustbucket Ranch
Got a question, did you have to re-route the brake lines after installing that crossmember? From what I've seen and read, the brackets for that crossmember come close to where the lines run through the frame rails.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
I got an LS (LQ4 6.0) and 4L80E for $575 along with 6 original 22.5 Tubeless Budd wheels. I am waiting on the tubular LS cross member kit to come in.
6.0 LS Engine Chevy Viking Swap
22.5 Tubeless Budd Wheels - 1958 Originals
Once I get the engine and transmission in, I'll be able to add modern 22.5 tires and this truck will be good to drive anywhere.
Nice Mike.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
[img]https://drive.google.com/open?id=1VGC8iAzLQgmyToNyE34TCwJr-45ILILu[/img]
[img]https://drive.google.com/open?id=1hgKQoHUfuaKCx-lWJziL1nzGTjaPrZ4U[/img]
[img]https://drive.google.com/open?id=1nKSORWPdYpVupuVWkQFGbxOgjOkiRPG9[/img]
[img]https://drive.google.com/open?id=1zSHPyVadOruUrekd9UrSkfT-Ytf2DPmv[/img]
6.0 LQ4, 4L80E, Lokar Shifter, Holley Intake and Holley 750CFM carb. 2011 Camaro SS Exhaust manifolds, Holley Blue Electric fuel pump.
NICE!!!
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
V
V Offline
I also have a 58 Viking and plan of driving fairly regularly. What do all of you Big Bolters do for insurance?
Crusing in the Passing Lane
Gulfway.
Ed
Shop Hagerty as well, they are an ATHS sponsor now insuring antique big rigs.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Just wanted to update my original thread, the truck is done except for brakes and tires. 1958 Chevy Truck Viking 60 2 ton LS Swapped
I just go a note from Gulfway, they are using Hagerty now.
Ed
J Apache Nice truck those Apache's were tough,Once built a 500 gallon spray truck for row crop work if you didn't let out of it would go thru about 8 inches of clay mud in a wet place with a full load of corn spray on. Those tall narrow wheels and tires worked. 327 with sm 420.
J Apache just replied to you-poof it disappeared will re- appear now majic ???
J Apache Nice one !
J Apache Dont know what I done there-not a computer whiz !! Sorry
