2 members (UtahYork, Joe H),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,018 Posts1,055,260 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 6 New Guy | | New Guy Joined: Jul 2018 Posts: 6 | Hi all,
I have a 1966 GMC 3/4 ton pickup w/120K miles. Engine is 305V6. I have been having ignition problems so I replaced the starter solenoid. Unfortunately when I turn the key, I get nothing. Battery is fine and alternator is new.
Could it be a voltage regulator issue? I welcome any thoughts. Thx
Tim | | | | | Joined: Dec 2002 Posts: 3,436 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,436 | Hello Tim and welcome to the 'bolt. I'm going to move this to the Electrical Forum where you will get better answers... and please re- introduce yourself in the welcome forum.. and post some pix when you get a chance.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What does a starter solenoid have to do with ignition?
What are the symptoms of your ‘ignition problems?’
Ed
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..........welcome to the Bolt. You are now home. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | I'm assuming your "ignition" problem is actually a "won't crank" issue. We tend to give advice here based on people being able to accurately describe what's going on. For instance a "no crank" problem (engine isn't turning) gets different advice than a "doesn't start" problem (engine turns but won't run). Reading between the lines of your very ambiguous post and making a lot of assumptions makes me believe you're actually describing an "engine doesn't crank" problem. Replacing the solenoid won't help- - - - -you probably have worn out brushes in the starter itself which is preventing the solenoid from getting a ground that allows it to pull the starter gear into engagement with the flywheel and start the engine turning. You can confirm that by having someone hold the key in the start position and tapping the starter housing (lightly) with a hammer. If that makes the engine start cranking, get the starter rebuilt by a competent professional, or replace it. Good luck! Jerry
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Uh, I'm not that well versed with many of the GM V6's starters. But be cautious when taking the starter off the bell housing. Most have shims, if one exchanges for a new or rebuilt you may find it very annoying trying to get it adjusted so the solenoid gears hitting the ring gear correctly so it is not too long. I had a V6 El Comino that I exchanged for a rebuilt rather than have the original rebuilt. I sure did learn to take a GM starter off & on fast after a few hours. I agree with Hotrod, tap that thing lightly while someone turns the key. Doc.
| | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Doc, the ones with shims usually bolt to the block, not the bellhousing. Since the pinion gear on that type of starter is slightly below the center line of the flywheel, shimming it further down keeps the teeth from bottoming out in the flywheel gear. The bellhousing-mounted ones generally don't give any problems. A sneaky trick to check tooth engagement is to paint a dozen teeth or so of the flywheel gear with a rattle can and spin the starter with the ignition disabled to see how much paint gets rubbed off. About a 90% tooth engagement with a bit of paint still showing at the bottom is ideal. Jerry
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | What (if anything) did the starter do before you changed it? Crank slow? Click and nothing else?
A little more details would be helpful. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Pretty sad and frustrating, but it happens all the time with new guys. I don't know why. They ask for help and then go to sleep. If you are too busy, don't ask for help until you are not too busy. 1. Ignition problems= not specific. I assume "I get nothing" means no grinding no noise no clicking no buzzing....... 2. Voltage regulator has nothing to do with cranking 3. Alternator has nothing to do with cranking (you must have an externally regulated alternator) You say battery is fine. 4. "Battery is fine". With what you have said so far, you are not experienced in electrical, so how do you know battery is "fine"? Did you test it? 5. Jump the starter down at the solenoid. This will bypass the ignition switch and some wiring. It will isolate to the solenoid, starter and battery cables (if battery is actually "fine"). I doubt it. 6. Your 66 GMC 305 V6 starting system is no different than a Chevy. No shims. No nothing special. 7. Please provide the solenoid part number, where you got it and a picture, or careful statement, of how you wired it.
Right now you have a "no crank" situation. We don't know what you had when you decided you needed a new starter solenoid. You called it "ignition problems". We are glad to help you but don't analyze the issue, or give it a name, just state what the motor is doing or not doing. We will ask specific questions and get you fixed. Provided you have not fallen off the edge of the earth and have no computer service. It's good, especially when new to a forum, to monitor your own post because you have good folks taking the time to help.
I don't know if you can post pics while moderated. Stay safe, See you next year.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2018 Posts: 6 New Guy | | New Guy Joined: Jul 2018 Posts: 6 | My apologies folks. I’m definitely a “new guy” and trying to figure out this Stovebolt platform. That and the holidays are the reason for my delay in responding. Yes when I turn the key in ignition, the truck doesn’t crank. The Generator light is illuminated and gages activate but no crank. I’m able to jump the start at the solenoid and and will try and tap starter to see if engine cranks. I purchased this truck two years ago and am still learning my way around this engine which was marketed as a half-million mile motor when marketed back in 1966. As a new guy, Please don’t take the naive questions personally.
Based on comments above, it appears one option is to rebuild the starter due to potentially warn brushes. LMC Truck doesn’t appear to have a starter for the 305V6 so is a rebuilt starter my only option? Also where can I look to research rebuilt starters for sale?
Thx
New Guy | | | | | Joined: Jul 2018 Posts: 6 New Guy | | New Guy Joined: Jul 2018 Posts: 6 | I appreciate the advice. I’ll report back on your comments shortly.
New guy | | |
