4 members (Peggy M, Jeff Ogden, cmayna, mk72), 46 guests, and 8 robots.
Topics128,012
Posts1,055,321
Members48,419
#1388339 12/14/2020 10:51 PM
I have replaced my foot starter boot twice in the past year; it seems to last a month or two before it starts to tear. I just received my third one and was wondering if maybe there is something I am doing wrong in the installation. These have all come from the usual catalog companies we all deal with, but I have not tried Steele yet (if they offer the part). Any suggestions?
Lee.
1956 Chevy 3200, 235 w/3 speed
LeeD #1388344 12/14/2020 11:12 PM
AD Addict & Tinkerer
I’ve had the same issue with the parking brake cable boots. They don’t fit properly and end up splitting within a few months. Cheap overseas crap!
Phil
Project Journals
Stovebolt Gallery Forum
LeeD #1388347 12/14/2020 11:33 PM
Try using the accordion boot for a rack & pinion steering gear instead. They flex thousands of times without failing. Only an anal-retentive purist is likely to notice the difference!
LeeD #1388450 12/15/2020 2:22 PM
The only thing I have thought of to try is to maybe make the hole in the boot a little bigger so as to slide easier along the shaft. I’ll also try cleaning the shaft well and maybe put some dry lubricant on it to allow the bellows to maybe not stretch out so much. When/if this one fails I’ll look into other boot options like Jerry suggested.
Lee.
LeeD #1388481 12/15/2020 4:35 PM
I had the same problem until I ordered one from Steele. Has lasted 10 plus years now.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
