0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Okay Stovebolters my truck is now undriveable and I need some direction: When driving the truck if I hit a bump or sometimes randomly it will begin to squeal, very loudly. It stops only when you stop and are at zero speed. It does not squeal at idle or when revving it in neutral. It still squeals with generator belt removed. Clutch is correctly adjusted for pedal play about 3/4” of travel before it engages. As above I cannot replicate with the truck in the driveway it only happens at speed. Is this a harmonic balancer issue or something else? Truck drives fine except for the intolerable squealing. Engine is a 1954 235, rebuilt by the previous owner, it has 15,000 miles on it since it was rebuilt in 2006. Thanks for any help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Brad Allen, if you could find an isolated road for test driving purposes, when the squealing starts, shut the engine off and coast, just to confirm it is indeed the engine making the noise and not other rotating parts. Let us know what you find out, good luck. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | It could easily be a water pump, generator bearing, or similar part that starts squealing after things warm up a bit. But you've eliminated the water pump and generator by removing the belt) The shaft of a bearing that's worn may start "walking" around inside the bore, (chattering from side to side) and cause the squealing. A bump can cause that to start and another bump could stop it. Is it speed related (change pitch with different speeds)? Anyway, my vote is a bearing. I'd check the front wheel bearings first to see if they're binding up, possibly causing the inner race of one to chatter on the spindle.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | When doing a test drive for a noise, driving along a wall really brings out the noise.
Ed
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Open drive? Dry u-joints.? Metal timing gears clashing? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Brad, could this possibly be a "wind" noise ??? I'm reaching here but your info kind of leads me in that direction.....I like the idea of driving along a wall and also, someone riding on the back when doing so....you know, left front, right rear ect ect..... | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I am going to check some things today if the weather holds, this is a squeal it so loud people walking turn and look. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Try coasting with the trans in neutral and the engine stopped, or get somebody to tow the truck with a chain to see if the engine is actually the problem. It sounds more like you're hearing a brake, U joint, or rear end bearing noise. Jerry
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Thanks Jerry I am hoping to do that type of testing weather permitting. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I'm going to guess a wheel/brake problem , maybe a broken brake return spring caught up , or even just a stone in the brake . As Jerry suggests , coasting may help identify the source. | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | My guess is a U-joint. I had a squealer like that too. Coast in neutral to take the load off of it. If it goes quiet it's probably a U-joint.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I assume this is a one piece driveshaft but if not then check the midship bearing.
| | | | | Joined: Apr 2010 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 242 | OK Brad, we can't have one of our first string quarterbacks on the sidelines. Has this problem been sorted out? Inquiring minds want to know. | | | | | Joined: Dec 2013 Posts: 771 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 771 | Has this problem been sorted out? Inquiring minds want to know. X2 | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | | | |
