0 members (),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,394 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | Those sure are perty tanks. Wunder how much they cost... 8-} | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Nice tank, but they don't even list it as available on their website. It would solve my tank issues if they decide to put it on the market. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Bot my aluminum tank from summit for 169 A genaric tank that is mounted beneath the bed in rear. | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Thanks Big Chevy 3600 I was having the same problem fireout1 was and couldn't find the one mentioned. But after looking at the pictures in the webrodder article it appears to me they used this one: http://www.tanksinc.com/index.cfm/p...ry_id=69/home_id=59/mode=prod/prd108.htm Or am I looking at it wrong? The one in the link you provided is for a 53/54 Car isn't it? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The thing is, those with a 3100 are likely to find a new tank that will fit. I don't doubt someone makes one. I couldn't find the Summit tank on their site. My problem is, with a 3600 and a more narrow frame rails than the 3100 I will probably need to find something that will fit or have one special made. I have seen somewhere someone makes tanks to order, I just can't remember where I saw it. My plan is to have the filler tube exit out the middle rear from behind the license plate like the cars of the 50/60s.
~Jim
| | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Robin58 that tank looks awful close to the one in the article. I think that would work out. | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Those blazer tanks would be nice, but the only problem I have is you have to move the rear crossmember which if you do you lose the frame support for your rear leaf spring bracket. I know some have done that conversion and maybe it's not a problem, but I would rather have a tank to fit the existing configuration. Just my preference. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I went the blazer route on my 3600 and I'm pleased with the results. It was a simple swap and fairly inexpensive.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well I just ordered one (blazer for 25.00 plus frt.). We will see how she fits.
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | mine came to me with a mid 70's caddy tank , My Uncle welded a pc of 2" angle cross the end of the frame rails ...an another up past the original crossmember and fitted teh straps to them ...it worked great till the tank went bad ....i removed it all and i am installin a fuel cell in the bed . | | |
