Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (51sub, farmallb, 1955 1 Series, walter74, TexasA&M48Truck, baldeagle, dt235sd, Charles in CA, 32Fordpuchoptop), 30 guests, and 2 robots.
Topics128,005
Posts1,055,256
Members48,418
#1383417 11/04/2020 12:45 PM
What does the jack look like that would be used on my 53 Chevrolet 3600. And where would you have kept it on the truck?
Not sure but, under the seat is my guess.
Thanks in advance.
Elmo
Elmo #1383496 11/05/2020 2:23 AM
Elmo,
I asked the same question some time ago and received this photo. I Was told the same jack was used from the early 40's through the 50's. Someone will correct this if wrong.
Here is a copy of the 1953 Truck Manual. It says there is a 50X19X6 tool box under the seat. This tool box is for the larger truck and is on page 72
Harold
Harold
Elmo #1383500 11/05/2020 2:46 AM
That is the correct look Jack, they were actually produced (or similar versions into the 1970’s) simple stampings, very cost effective for GM. I have heard they were in a bag of some kind (never seen one) most people think they were loose under the seat. I have also never seen AD period original instructions on storage provisions.
https://www.flickr.com/photos/advance-design_parts_co/8129502216/in/album-72157631868452754/
One of two I have found in trucks, one in a ‘49 one in a ‘53.
https://www.flickr.com/photos/advance-design_parts_co/16079459486/in/album-72157631868452754/
The two handles, ‘53 version was shorter.
https://www.flickr.com/photos/advance-design_parts_co/16105224175/in/album-72157631868452754/
Extended view.
https://www.flickr.com/photos/advance-design_parts_co/45119759105/in/album-72157631868452754/
Documentation is Yeti like in its rarity.
Brad Allen #1383574 11/05/2020 10:42 PM
My 1953 1/2 ton 3 window came with a scissors jack that works and crank to turn the engine over thru the lower grille. Are those jacks available around?
Elmo #1383581 11/05/2020 11:31 PM
eBay and Swap Meet are your best bets, I see the jacks fairly often, the handles almost never.
Harold46 #1383641 11/06/2020 2:25 PM
Originally Posted by Harold46
Elmo,
Harold
Thank you, Harold46
Elmo #1383664 11/06/2020 7:26 PM
Elmo,
Always happy to help,
Harold
Harold
Elmo #1384464 11/14/2020 2:40 AM
That original jack design is called a bottle jack. Very popular amongst other car mfg's as well.
Craig
Harold46 #1384470 11/14/2020 3:50 AM
Harold[/quote]
What page (pages) of the are you referring to?
What model of truck are you referring to?
I have not looked through that entire Specifications Manual, but I see that a “tool box” of different dimensions being referred to for many models - I might be wrong, but I think that might be referring to the underseat/underfloor storage compartment?
A jack, wheel wrench, and a jack handle are the list of tools for most models?
An additional Tool Kit (bag and tools) is referred-to in the ACCESSORIES section on page 159?
This had to be ordered in addition-to (separate-from) the truck/options delivered from the factory.
tclederman #1384496 11/14/2020 12:43 PM
Sorry ohwell it is for the larger truck and is on page 72
Harold
Harold
Elmo #1390970 01/02/2021 9:22 PM
brad allen re. jack I have aniron one with exposed gears and an iron flip top that gives you about 2 inches more hight. It is associated with the big bolts I think... works OK.
Elmo #1391064 01/03/2021 3:51 PM
This Jack is illustrated in the 1947-48 owners manual, does the Jack look like this? I have never owned one of this type.
https://www.flickr.com/photos/advance-design_parts_co/50175790437/in/album-72157631872034068/
