3 members (GIJOE298, Gray_Ghost, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,078
Posts1,056,056
Members48,433
1 Offline
Well... Ever since I launched the power steering rack on the 51 and found out about the Pressure regulator for the pump Ive been looking for one and cant find it, I called my supplier and they said they don't carry one ?? Does anyone know where I can find a Regulator for the rack ??
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Junior Member
Junior Member
Checkout Speedway Motors. www.speedwaymotors.com
They have them in their catalog.
item #91032918 $19.95
1 Offline
Thanks I'll check it out
Todd
Todd,
You can also install shim washers in the pump flow valve.
Bill's Hot Rod in Covina, CA makes a shim kit to reduce the GM pump pressure. The Mustang II rack operates at about 900 PSI, the GM pump puts out about 1300 PSI. You would need 3 to 4 shims for it to operate correctly.
FRed
www.heidts.com has an adjustable valve that lets you adjust from full on power or manual. a little pricey but worth looking at. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
