| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Well... Ever since I launched the power steering rack on the 51 and found out about the Pressure regulator for the pump Ive been looking for one and cant find it, I called my supplier and they said they don't carry one ?? Does anyone know where I can find a Regulator for the rack ??
Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Jul 2006 Posts: 23 Junior Member | | Junior Member Joined: Jul 2006 Posts: 23 | Checkout Speedway Motors. www.speedwaymotors.com They have them in their catalog. item #91032918 $19.95 | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Thanks I'll check it out Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Todd, You can also install shim washers in the pump flow valve. Bill's Hot Rod in Covina, CA makes a shim kit to reduce the GM pump pressure. The Mustang II rack operates at about 900 PSI, the GM pump puts out about 1300 PSI. You would need 3 to 4 shims for it to operate correctly. FRed
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | www.heidts.com has an adjustable valve that lets you adjust from full on power or manual. a little pricey but worth looking at. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
