1 members (dt235sd), 101 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#138176 05/21/2007 12:57 PM
I had a question regarding my exhaust on my '66 283. I didn't know whether to put this in the
HI PO section, but here goes.
My truck is a stock '66 fleetside with 283, 3 speed. The motor is done and looks nice, but can't decide on the exhaust. I am told that the headers run cooler with the ceramic coating. I don't mind putting them on if this is the case.
Would dual exhaust be better for this? I don't want to discolor the engine with overheating.
The other issue is the boss on the stock manifold has a place for the alternator, don't know about the headers.
Any comments are appreciated.
thanking you
GWS
GS
#138177 05/21/2007 7:17 PM
I like the ceramic coating - it does dissipate heat better and looks great. As for duals, it's up to you, I don't think the original exhaust would overheat the engine and discolor it but I like duals. You can run them quiet or loud or anything in between. Also look nice with chrome tips. Just my opinion.
#138178 05/21/2007 7:50 PM
I have the old Rams horn cast iron exhaust and am very happy they don't leak like some headers do. You can buy a chrome piece that covers them very nicely Will send you a pic if you want
#138179 05/21/2007 8:19 PM
I dont like headers,, to me they put way to much heat in the cab.. at least they did on my 52 five window.. that sucker would bake you if you got stopped in traffic long...
Fred
Redryder pix
My Hotrod
#138180 05/21/2007 9:09 PM
Riding in the Passing Lane
I like the original ramhorns & the performance guys say they are just as good unless you are going raceing. I like duals with real long glasspacks. Sounds great.
1972 Chevy c10 Cheyenne Super
#138181 05/21/2007 10:01 PM
I don't know what the original diameter is for the rams horn, but is it OK to take heat away?
I want to keep that engine pretty looking with the new paint.
GWS
GS
#138182 05/21/2007 10:28 PM
I have been running headers for a long time and they have their disadvantages. The headers will require replacing from time to time. It isn't just that they can corrode from the outside, but they also corrode from the inside. You have more noise in the cab with headers, and you also lose the heat riser which can make running in cold, or damp weather a problem until the engine warms up.
Like Wrenchbender says, you don't start to see the difference in power unless you are running at high RPM. A stock manifold with dual glasspacks sounds almost as good as tuned headers and costs less in the long run.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
#138183 05/22/2007 1:09 PM
I am sticking with the Rams horn manifolds , thought abough the headers, but been down the road with the leaks an noise and heat in previous projects ...I think the Rams horns breath well clear the starter really nice and with duals you will like it better in the long run , just my 2 cents
1952 Chevy Shortbed
Photos in Photobucket
#138184 05/23/2007 8:39 AM
when i buy a ride if its got good headers i leave them i have a set on a 77 chevy 20 years old still not leaking and working good but i like cast iron better takes up less room just dont have a nice sound like headers but headers can be a real pain sometimes
#138185 05/23/2007 9:13 PM
Eastwood has some exhaust manifold paint that makes them look like new cast iron. It,s very high temp. & lasts a long time.
#138186 05/24/2007 2:34 PM
Speedway products won a award for making repop rams horns. Look great but kinda spendy.
