| | | Forums66 Topics128,268 Posts1,058,382 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I had a question regarding my exhaust on my '66 283. I didn't know whether to put this in the HI PO section, but here goes. My truck is a stock '66 fleetside with 283, 3 speed. The motor is done and looks nice, but can't decide on the exhaust. I am told that the headers run cooler with the ceramic coating. I don't mind putting them on if this is the case. Would dual exhaust be better for this? I don't want to discolor the engine with overheating. The other issue is the boss on the stock manifold has a place for the alternator, don't know about the headers. Any comments are appreciated. thanking you GWS
GS
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I like the ceramic coating - it does dissipate heat better and looks great. As for duals, it's up to you, I don't think the original exhaust would overheat the engine and discolor it but I like duals. You can run them quiet or loud or anything in between. Also look nice with chrome tips. Just my opinion. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I have the old Rams horn cast iron exhaust and am very happy they don't leak like some headers do. You can buy a chrome piece that covers them very nicely Will send you a pic if you want | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I dont like headers,, to me they put way to much heat in the cab.. at least they did on my 52 five window.. that sucker would bake you if you got stopped in traffic long...
Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I like the original ramhorns & the performance guys say they are just as good unless you are going raceing. I like duals with real long glasspacks. Sounds great. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I don't know what the original diameter is for the rams horn, but is it OK to take heat away? I want to keep that engine pretty looking with the new paint. GWS
GS
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I have been running headers for a long time and they have their disadvantages. The headers will require replacing from time to time. It isn't just that they can corrode from the outside, but they also corrode from the inside. You have more noise in the cab with headers, and you also lose the heat riser which can make running in cold, or damp weather a problem until the engine warms up. Like Wrenchbender says, you don't start to see the difference in power unless you are running at high RPM. A stock manifold with dual glasspacks sounds almost as good as tuned headers and costs less in the long run. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I am sticking with the Rams horn manifolds , thought abough the headers, but been down the road with the leaks an noise and heat in previous projects ...I think the Rams horns breath well clear the starter really nice and with duals you will like it better in the long run , just my 2 cents | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | when i buy a ride if its got good headers i leave them i have a set on a 77 chevy 20 years old still not leaking and working good but i like cast iron better takes up less room just dont have a nice sound like headers but headers can be a real pain sometimes | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Eastwood has some exhaust manifold paint that makes them look like new cast iron. It,s very high temp. & lasts a long time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Speedway products won a award for making repop rams horns. Look great but kinda spendy. | | |
