| | | Forums66 Topics128,007 Posts1,055,279 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | Hi, my '37 1/2 ton has a re-cored radiator, re-cored heater core, new water pump and new 160 degree thermostat, all done this year. The engine runs at approximately 170 degrees at idle (it's 34 degrees in the garage today) down from approximately 180 degrees this summer. The heater hoses are hot but the radiator hoses are just warm. Sticking my high tech temp sensor (my right forefinger) in the coolant at the radiator cap I find it's lukewarm. I also don't see any circulation at the top of the radiator. Is the thermostat stuck? Thanks John | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | Not stuck, just working as it should. If the engine isn't making heat, the thermostat will not open. It is opening just enough to maintain the correct heat in the motor. | | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | | | |
