2 members (Otto Skorzeny, Roy Rodgers), 103 guests, and 3 robots.
Topics128,042
Posts1,055,518
Members48,424
#1381545 10/20/2020 7:59 PM
' Offline
Hi, my '37 1/2 ton has a re-cored radiator, re-cored heater core, new water pump and new 160 degree thermostat, all done this year.
The engine runs at approximately 170 degrees at idle (it's 34 degrees in the garage today) down from approximately 180 degrees this summer.
The heater hoses are hot but the radiator hoses are just warm. Sticking my high tech temp sensor (my right forefinger) in the coolant
at the radiator cap I find it's lukewarm. I also don't see any circulation at the top of the radiator.
Is the thermostat stuck?
Not stuck, just working as it should. If the engine isn't making heat, the thermostat will not open. It is opening just enough to maintain the correct heat in the motor.
Joe H #1381827 10/22/2020 6:56 PM
' Offline
