1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Well...after collecting parts for six months I finally dove in and started putting power disc brakes on the '63 that originally left the plant attached to a '79. Pics below... Front End | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Tex, Did you buy a kit with new spindals or acculimate parts from stock replacment? | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I got the spindles, steering linkage, Vac booster, MC, etc off a wrecked '79 C-10. I did get a new (remanufactured) MC from FLAPS using the old one for core.
All of the bearings, ball joints, tie rod ends, seals, etc are new from FLAPS. I ordered the ball joints, tie rods, wheel bearings, etc to match the '79, and the upper and lower control arm bushings to match the '63.
The 2" drop springs and sway bar kit came from CPP.
Wilwood Prop valve and 10 psi residual valve came from Summit.
Hopefully tonight after work I'll get the rest of the brake lines bent and in place so that I can back it out of the garage, turn it around and install the rearend out of the same '79. | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Forgot to mention...I also got an Wilwood adjustable prop valve and 10 psi residual valve from Summit. | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | Forgot to mention...I also got an Wilwood adjustable prop valve and 10 psi residual valve from Summit. | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | The spindles, rotors, Vac booster, steering linkage, etc came off a wrecked '79 C-10.
Bearings, tie rod ends, ball joints, seals, brake lines, etc came from FLAPS.
Wilwood adjustable prop valve and 10 psi residual valve came from Summit.
2" drop springs and sway bar kit came from CPP. | | | | | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | OK...this is getting strange. I replied once and nothing happened. When I replied the second time the first response came up??  | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 |
