9 members (Peggy M, Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, 1 invisible), 69 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
Well...after collecting parts for six months I finally dove in and started putting power disc brakes on the '63 that originally left the plant attached to a '79. Pics below...
Front End
Daily Driver 63 C-10 LWB Fleetside
Tex, Did you buy a kit with new spindals or acculimate parts from stock replacment?
I got the spindles, steering linkage, Vac booster, MC, etc off a wrecked '79 C-10. I did get a new (remanufactured) MC from FLAPS using the old one for core.
All of the bearings, ball joints, tie rod ends, seals, etc are new from FLAPS. I ordered the ball joints, tie rods, wheel bearings, etc to match the '79, and the upper and lower control arm bushings to match the '63.
The 2" drop springs and sway bar kit came from CPP.
Wilwood Prop valve and 10 psi residual valve came from Summit.
Hopefully tonight after work I'll get the rest of the brake lines bent and in place so that I can back it out of the garage, turn it around and install the rearend out of the same '79.
Forgot to mention...I also got an Wilwood adjustable prop valve and 10 psi residual valve from Summit.
The spindles, rotors, Vac booster, steering linkage, etc came off a wrecked '79 C-10.
Bearings, tie rod ends, ball joints, seals, brake lines, etc came from FLAPS.
Wilwood adjustable prop valve and 10 psi residual valve came from Summit.
OK...this is getting strange. I replied once and nothing happened. When I replied the second time the first response came up?? ohwell ohwell
Looking good...
Another quality post.
Real Trucks Rattle
