0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | I am installing a 400 small block in my 66 half ton. It used to be a 283. One problem though. On the 283 there was a place for a ball stud to screw into the engine. The clutch linkage mounts off of it. On the 400 engine there is no such fitting. Does someone make a bracket that would bolt to the bellhousing to overcome this problem ? I know I am not the first guy to face this problem ?
55 Cabover
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Hey Greg, I've done that modification to my '64. I used the ball stud that threads into the block and mounted it to some heavy flat stock. I used a couple of bolt holes in the side of the block to attach the flat stock and then lined up the Z bar to locate where the ball stud goes. Drill a hole and put a nut on the back of the ball and you're done. Hope I didn't confuse you. I did this quite a few years ago, so the details are a little fuzzy, Scott | | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | That sounds right to me. I was just hoping that some company would have made a bracket by now so i don't have to fabricate one. Did you use quarter inch stock ? Should be interesting to see how much better the 400 moves the truck over the 350 I had in it.
55 Cabover
| | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | Scott, any more progress on Bubba lately ?
55 Cabover
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | I'll send you an e-mail tonight. We've had some family drama that took the wind out of our sails for a while but we're about to fire up the shop again, Scott | | | | | Joined: Aug 2005 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 58 | Hey Scott, went to my mechanic and we looked at some old blocks he had around. There is a place on the block that just needed to be drilled and tapped for the stud. Did that over the weekend so I have no more excuses. Time to drop the new motor in.
55 Cabover
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Good deal! Bring it to the show this summer so I can see it, Scott | | |
