9 members (greenie-reddy, UnclePaddy, 1955 1 Series, porsche, Oswald, Otto Skorzeny, Bill Hanlon, Maybellene, TUTS 59),
104
Mod | | | Forums66 Topics128,279 Posts1,058,458 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | Here's a super tough one for you. Dipstick broke off in tube on 235. It's about an inch down from the top. Tried everything. Thinking I should pull tube out of block. How is it held in? What am I going to break by removing it? Assume it's just pressed in but don't want to break off in the block.
Thanks. | | | | | Joined: Aug 2019 Posts: 242 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 242 | Yep, it's pressed in. Mine came out with some vice grip twisting... oily spot, good chance it's not rusty.
If you're worried maybe tap a screw into it and use something to slide hammer.
FYI: it's easily replaceable with 3/8 steel tube if you can figure out the correct length.
'59 Chevy Suburban, NAPCO
| | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Put a 5/16” bolt in the tube first and clamp down on that so you don’t crush the tube, then twist and lift.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Do the bolt and vise grip approach, but slide a big 1/2" drive deep socket over the tube first. Use the socket like a slide hammer. Jerry
| | | | | Joined: Jul 2018 Posts: 287 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 287 | And here’s your opportunity to put in a longer dipstick! So it will reach the oil😆
~Charley 1954 Chevy 3100 with 235“Bud”Follow along in the DITY1963 Chevy half ton stepside short box 230 1954 GMC 3 ton 302 And several more Chevy camper and work trucks 1979 1987 1996 | | |
