1 members (klhansen), 65 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#1376187 09/06/2020 11:27 PM
Here's a super tough one for you. Dipstick broke off in tube on 235. It's about an inch down from the top. Tried everything. Thinking I should pull tube out of block. How is it held in? What am I going to break by removing it? Assume it's just pressed in but don't want to break off in the block.
Thanks.
Yep, it's pressed in.
Mine came out with some vice grip twisting... oily spot, good chance it's not rusty.
If you're worried maybe tap a screw into it and use something to slide hammer.
FYI: it's easily replaceable with 3/8 steel tube if you can figure out the correct length.
'59 Chevy Suburban, NAPCO
Thank you.
Put a 5/16” bolt in the tube first and clamp down on that so you don’t crush the tube, then twist and lift.
My Blog
Do the bolt and vise grip approach, but slide a big 1/2" drive deep socket over the tube first. Use the socket like a slide hammer.
And here’s your opportunity to put in a longer dipstick! So it will reach the oil😆
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
