0 members (),
126
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 3,455 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,455 | Has anyone seen or used the "NEW" kit from NoLimit? It is supposed to be a bolt in rack and pinion unit that works with out clearence issues.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I haven't and won't use it.
If you do some searching here you'll find several threads on the subject. My feeling is rack and pinion on a straight axle is not a good choice.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't like the idea either. You got a questionable connection from the column to the rack, plus it would add alot of extra unsprung weight to an already heavy front axle. Besides, REAL trucks don't have power steering!
Bill Burmeister | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Just a thought for anyone who wants to try.... I know there is a geometry issue using standard R+P on a straight-axle, mounted to the cross-member (fixed to the frame). If a center-action rack were used, with a cross-link to the tie-rod, would the geometry be much different than that of a modern truck with normal power steering?
I ask as I have changed the rack on my Z24, and that rack has the tie-rods attached to the center, rather than the ends.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, the center mount type tie rods will make the problem worse. What happens is the toe will change as the suspension moves up and down. That's why a rack, either regular or center mount, would have to be solid mounted to the axle. Either way, the safety would be marginal at best and I don't believe that there will be any gains in handling, especially wiht the added weight on the axle.
Bill Burmeister | | | | | Joined: Mar 2007 Posts: 3,455 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,455 | Not sure where this set up mounts, I believe that it bolts to the axle it's self. I tried to pull up some pic's of the install but couldn't get it to download. I only ask because I'm at this point with the frame rebuild. Keep in mind that I have a drop front axle (3")and a sway bar. I may use the tried and true Saginaw box.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | another way to get power is to get the flaming river electric power setup with their new steering column. goes to manual if the power fails. ron. www.flamingriver.com
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | From what I have read and seen, the problem is with the column mounting to the rack, if its solid mounted to the axle. You will need a slip joint in the column someplace so the axle can move up and down. A slip joint wounldn't be that bad only its not a true inline slip, its more of a up and down, in and out slip, and keeping it all inline and free, worries a lot guys. There are some that make it work pretty well and are totaly happy with them. If you mount the rack to the frame like normal modern stuff, then you have to worry about bump steer every time you see a hump in the road. There seems to be no way to get the tie-rods on the same plain as the axle and keep them there through the whole ark of the spring movement.
A better chice would be a power assisted ram clamped to the draglink like bigger trucks used. Or a power assisted gear box adapted to the original steering arms.
Just my 2 cents worth, Joe | | | | | Joined: Mar 2007 Posts: 3,455 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,455 | I think that no matter what the end result is it will require a lot more reading. After hearing some of the issues all of you have brought up I tend to be leaning more towards the power assist box. I have seenthis on more than a few trucks so it must work well. Thanks for the 411.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I installed this set-up in my Chevy '51 1/2 PU (since sold) it was a very easy install and it worked very well. The only problem I ever had was some ps hose leakage and that was easily repaired. There were no geometry issues and the setup was relatively light...weight was of little consequence on a truck that has a 770 lb engine. | | | | | Joined: Sep 2006 Posts: 33 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 33 | Hello All, I purchased the rack and pinion unit from No-Limit right after they came out. Installation was pretty straight forward. The rack bolts to the straight axle with 3 u-bolts. The steering arms that came with the kit were big and beefy. The kit also had a slip steering shaft and joint. Bolted right up to my ididit steering column.
BUT (yep there is a but), I had problems with the steering shaft hitting the header on drivers side (V-8). The only solution was to cut the header apart and make it wrap around the steering shaft. Since I'm a lazy SOB, and I didn't want to cut my header apart, I took off the rack and pinion and went back to regular power steering. I believe the rack and pinion would be great for a straight six. It would be another alternative for someone who wanted to retain the straight axle.
Big Mike | | | | | Joined: Apr 2006 Posts: 87 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 87 | there are cars turning up in junkyards now here in england with factory fitted electric powere coloumns quiet a few are finding there way onto rods etc
i may well go this route if pas is actually needed??
i also considered an old lincoln pas box i have one allready here would that be an option? | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Another thing to consider is whether you need power steering at all. I've been debating this for a while and right now am leaning towards a reversed corvair manual steering box and the stock column. That'll keep the stock look and reduce the number of turns lock-to-lock.
| | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Most Corvair boxes are aluminum (I think the early ones were cast iron). I've reversed some Corvair boxes for local rodders and would consider the aluminum ones I've worked on to be too light duty for a pickup. I think they work fine for a T-bucket or something similar in weight though. | | | | | Joined: Mar 2007 Posts: 3,455 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,455 | This truck will be just that a truck. It will pull an occasional trailer and haul the Harley once in a while. The point is that it will be a daily driver and expected to manage daily freeway as well as around town driving. Lowered with a V8 4 speed, power brakes the next move is of course power steering. I have driven it for years without it but it's time for a change.
