5 members (UtahYork, Bucker, Buckeye998, Stovebolt48, Hotrod Lincoln), 152 guests, and 2 robots.
Topics128,190
Posts1,057,339
Members48,469
Does anyone recommend one brand of fuel cell over another? I'm definitely going with aluminum, just didn't know if it was ok to order a plain jane one from Summit Racing, or something different.
I'm definitely trying to stay in the 200 dollar bracket.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
Wow, nobody has any input? Maybe I should be posting this on a dragster site instead?
Probably should have posted in the HiPo Forum. 👍🏻
I hesitate to reply because I'm not expert enough on fuel cells to give advice. All I know is that I've bought the Summit Racing units and they were good quality and worked very well - especially considering your budget.
1951 Chevy Panel Truck
Crusty Old Sarge
Crusty Old Sarge
Both Summit and Jegs offer quality units at a reasonable price. Talk to one of their Tech Reps , you'll need to have information on size and filler neck location, fuel injection (larger pump opening) and type of fittings, they should be able to fix you right up.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I have a Stainless steel 26 gal under the bed for my ‘39 w/‘54 235
Look up Rick’s Tanks out of El Paso, Tx
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Mario, do you have a pic with the tank fitted under the truck???? I have a plan for my 37 one day soon...maybe.
When I read fuel cell I think of the ones hotrodders put in their trunk or in the case of a truck on the bed near the cab.. Are you wanting a fuel tank?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
