1 members (Southerntruck),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | I am planning on putting a power brake booster on my 1950 3100 truck. I know they make the expensive ones that go under the truck on the frame and the ones that go under the dash, but I am thinking about just plain and simple mounting it on the firewall on the driver's side and was wondering which model of car works well?
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Scott, I used the swing pedal, Master cylinder and booster from a GM G body (Cutlass, Regal, Grand Prix, Monte Carlo. You will need to reinforce the firewall to withstand the added force from the pedal. There should be some pics on my picture trail album of this but if there is not enough info there let me know and I will dig some other pics up for you. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | thank you, any other suggestions?
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Scott A 1973 thru 87 Chevy truck works nice too, I got a real nice aftermarket firewall mount online that fits sweet (7" booster,M/C, pedal assembly) the pedal assembly takes the place of the dash/steering wheel brace, it really worked out nice and clean. Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I used a mid 70's booster and a 70 C10's master along with a home made mounting bracket and kept it all under the floor too. I have a little more room to work with it being a 1 1/2 tonner, but I think there are smaller diameter boosters that would fit a pick-up just as well. All of the pedal and linkage parts are already there, so I thought that would be the best way to go. I wouldn't mount one to the firewall with out beefing it up somehow, it's just a single layer of sheet metal, Scott | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | on ebay search 7 inch dual booster you can pick one up with the corvette style master cylinder, with two ports on each side for about $130.00. use your original peddle and design a card pattern bracket make your bracket and weld it in. with a 3 inch hole saw drill a hole in the floor above the filling cap and use a factory plug for the floor. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I am keeping mine on the frame to keep the firewall clean but I can only give you this advice. Do not choose a MC and booster that are so big it is all you see when you lift the hood. I have seen MCs on the firewall that is small and less obtrusive and I would look to install something like that.
~Jim
| | | | | Joined: Jan 2007 Posts: 27 Junior Member | | Junior Member Joined: Jan 2007 Posts: 27 | Check out the brake boosters and master cylinders at Jegs to get some ideas. I looked at a bunch of setups at the local "Pick&Pull" the other day that could work. Best entertainment for 1$ Wick
Every Hour you spend Fishing adds A Day to your Life!
