6 members (Gdads51, Otto Skorzeny, Opelika Tom, crenwelge, 78buckshot, 1 invisible), 103 guests, and 2 robots.
Topics128,062
Posts1,055,851
Members48,428
#137388 03/08/2007 4:20 PM
I am planning on putting a power brake booster on my 1950 3100 truck. I know they make the expensive ones that go under the truck on the frame and the ones that go under the dash, but I am thinking about just plain and simple mounting it on the firewall on the driver's side and was wondering which model of car works well?
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#137389 03/08/2007 5:17 PM
Anonymous
Unregistered
Anonymous
Unregistered
Scott,
I used the swing pedal, Master cylinder and booster from a GM G body (Cutlass, Regal, Grand Prix, Monte Carlo. You will need to reinforce the firewall to withstand the added force from the pedal. There should be some pics on my picture trail album of this but if there is not enough info there let me know and I will dig some other pics up for you.
#137390 03/08/2007 6:00 PM
thank you, any other suggestions?
1967 Chevelle 300
#137391 03/09/2007 6:25 PM
1 Offline
Scott
A 1973 thru 87 Chevy truck works nice too, I got a real nice aftermarket firewall mount online that fits sweet (7" booster,M/C, pedal assembly) the pedal assembly takes the place of the dash/steering wheel brace, it really worked out nice and clean.
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#137393 03/10/2007 2:48 AM
I used a mid 70's booster and a 70 C10's master along with a home made mounting bracket and kept it all under the floor too. I have a little more room to work with it being a 1 1/2 tonner, but I think there are smaller diameter boosters that would fit a pick-up just as well. All of the pedal and linkage parts are already there, so I thought that would be the best way to go. I wouldn't mount one to the firewall with out beefing it up somehow, it's just a single layer of sheet metal,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#137394 03/10/2007 6:17 AM
on ebay search 7 inch dual booster you can pick one up with the corvette style master cylinder, with two ports on each side for about $130.00. use your original peddle and design a card pattern bracket make your bracket and weld it in. with a 3 inch hole saw drill a hole in the floor above the filling cap and use a factory plug for the floor.
1949 SUBURBAN
#137395 03/12/2007 11:14 PM
I am keeping mine on the frame to keep the firewall clean but I can only give you this advice. Do not choose a MC and booster that are so big it is all you see when you lift the hood. I have seen MCs on the firewall that is small and less obtrusive and I would look to install something like that.
~Jim
#137396 03/13/2007 3:58 PM
Junior Member
Junior Member
Check out the brake boosters and master cylinders
at Jegs to get some ideas. I looked at a bunch
of setups at the local "Pick&Pull" the other day
that could work.
Best entertainment for 1$
Wick
Every Hour you spend Fishing adds
A Day to your Life!
