4 members (KEVINSKI, Nick in Manitou, FishinToms53, mick53), 74 guests, and 2 robots.
Topics128,126
Posts1,056,353
Members48,441
#1373218 08/13/2020 5:06 PM
My 1947 3100 pickup transmission has the floor shifter. It is actually 3 forward speeds with reverse. My understanding is this transmission is factory original to this truck. How can I learn what transmission (name/model) is in my truck? Does the transmission have this information stamped on it somewhere? Thanks, Ray
The GM part number is shown here.
Maybe someone knows what the casting number is on the case?
There might also be a date casting code on the case?
Insomniac
Insomniac
Check the 1947 vehicle information kit: https://www.gmheritagecenter.com/do...hevrolet-Trucks/1947-Chevrolet-Truck.pdf
Should be a serial number stamped on the transmission somewhere. Prefix code indicates manufacturer.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Crusing in the Passing Lane
Are the top 2 gears synchronized?
Ed
I'm not sure. I have not taken it apart.
24601
Buck -- as for Ed's question, do you have to double clutch all three gears when you drive it? If yes, then they're not synchro'd.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I checked the service manual and it is a 3 forward - one reverse selective syncro-mesh transmission. I think gears 2 and 3 are sorta synchronized. Manual didn't give any name for transmission or model numbers. ray
