| | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | My 1947 3100 pickup transmission has the floor shifter. It is actually 3 forward speeds with reverse. My understanding is this transmission is factory original to this truck. How can I learn what transmission (name/model) is in my truck? Does the transmission have this information stamped on it somewhere? Thanks, Ray | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The GM part number is shown here.Maybe someone knows what the casting number is on the case? There might also be a date casting code on the case? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Are the top 2 gears synchronized?
Ed
| | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | I'm not sure. I have not taken it apart. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Buck -- as for Ed's question, do you have to double clutch all three gears when you drive it? If yes, then they're not synchro'd.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | I checked the service manual and it is a 3 forward - one reverse selective syncro-mesh transmission. I think gears 2 and 3 are sorta synchronized. Manual didn't give any name for transmission or model numbers. ray | | |
