Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Crimson48, Phak1, 1955 1 Series, Frank50, CuzzFuzz), 37 guests, and 1 robot.
Topics128,006
Posts1,055,272
Members48,418
#1370123 07/22/2020 1:13 AM
got a 1937 gmc truck 1/2 ton and only has the handle and top cover [vent] I need the rest of it does any body know where I can get one. thanks
robert b #1370157 07/22/2020 11:10 AM
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
robert b #1370171 07/22/2020 1:31 PM
Robert B,
I have an extra one of the small flat metal piece depicted in the link that olezippi provided above. It has the curved serrated edge. You will need a spring as shown, as well as small carriage bolts for the hinges (these can be obtained at the Filling Station). I can also take a picture of my truck from underneath the dash, which will, hopefully, show how it goes together. I will post more later today.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
robert b #1370184 07/22/2020 4:28 PM
I couldn't take a suitable picture of my truck; too many wires and cables in the way. So I mocked up my extra parts. I glass beaded the part you are missing, coating it in a light spray lacquer so it won't flash rust. There is light pitting from the rust but it is entirely serviceable.
In the photo, the parts are posed as if you are looking at it from under the dash from the passenger side. Front is to the right and rear to the left. The part you need has a bigger hole to the front; that is for a bolt that acts like a hinge, that attaches to the cab just forward of the vent. The rear has a smaller hole; that is for a spring which attaches to the cab.
You may need the hinge bolts that hold the vent to the cab. As I mentioned above the Filling Station has small carriage bolts. If you look at Jim Carter he has bolts that have the proper shoulder on them to that the vent pivots on a shaft, rather than on the threads. He lists them back to 1939 and I don't know if they would fit the 37 or if they are even necessary. You could try a hardware store bolt first to see if they would work and would save some $$.
As a new person on this forum I think you need 5 posts before you can send a private message. You can message me and we can arrange to get this part to you. The price would be less than the postage!
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
robert b #1370204 07/22/2020 7:34 PM
.....and you can get a spring at Ace Hardware.
these pics may not help and it doesn't show the spring.
ok that will work i'll need your address and price and thank you much
robert b #1370291 07/23/2020 3:11 AM
We will communicate by private message. You need a few more posts before you are allowed to do that by forum rules.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
robert b #1370311 07/23/2020 12:23 PM
Robert b, send Kent an email. His email address is in his profile. And as he said post some more so you have the full use of Stovebolt.com.🛠
robert b #1370397 07/23/2020 11:35 PM
i tried pic click but ebay shows not found owell
robert b #1370659 07/25/2020 8:16 PM
robert b,
I sent you a private message.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Moderated by  ndkid275, Phak1
