3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | OK. So curiosity got the better of me and I tore down the 305 I have. Everything mics out standard. Very little wear. Block decodes as a 78-79 casting. The heads decode as 80-86 Lt. Truck. PO says it came out of an 84 C-10. My question is whether this is the original engine or a rebuild. Would a 78-79 block be used in an 84 production? The heads agree with the model year for sure. | | | | | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | If you are sure about the year of the block then I sounds like a replacement, the PO may not have had any idea the engine was replaced at some point.
Sean
doing what you love is happiness loving what you do is freedom
| | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Its not very likely that they would still have or be using blocks from the 70s for mid yr 80s production clint. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A '79 block with an '80 head would be reasonable. Maybe it was an '80 truck? The C-10s from those years are all almost the same.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Might be someone put a reman motor in at some time. Have you checked the bore or the crank for signs its been worked on?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
