3 members (moparguy, Bill Hanlon, 1 invisible), 59 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#136738 01/12/2007 8:16 PM
OK. So curiosity got the better of me and I tore down the 305 I have. Everything mics out standard. Very little wear. Block decodes as a 78-79 casting. The heads decode as 80-86 Lt. Truck. PO says it came out of an 84 C-10. My question is whether this is the original engine or a rebuild. Would a 78-79 block be used in an 84 production? The heads agree with the model year for sure.
#136739 01/13/2007 1:45 AM
1 Offline
If you are sure about the year of the block then I sounds like a replacement, the PO may not have had any idea the engine was replaced at some point.
Sean
doing what you love is happiness
loving what you do is freedom
#136740 01/21/2007 7:09 PM
Its not very likely that they would still have or be using blocks from the 70s for mid yr 80s production clint.
#136741 01/23/2007 1:54 AM
A '79 block with an '80 head would be reasonable. Maybe it was an '80 truck? The C-10s from those years are all almost the same.
Paint & Body Shop moderator
#136742 01/23/2007 3:14 AM
Might be someone put a reman motor in at some time. Have you checked the bore or the crank for signs its been worked on?
