3 members (TUTS 59, 1955 1 Series, dt235sd), 97 guests, and 2 robots.
Topics128,141
Posts1,056,488
Members48,441
#1366650 06/27/2020 1:35 PM
Hi all, does any one know what material was used to seal the hinges to the firewall/cowl?
The factory assembly manual , sect 14 sheet 4 indicates 466943 plastic cement 1/16" thick around holes. I can tell you that when I removed the hood hinges on my 1954 3604 that the material was not a hard material, it was pliable. Todays plastic seam sealer drys rock solid and would not allow any adjustment. Hopefully others with more knowledge can chime in an advise what modern material should be used? Maybe plummers putty?
Ron - - Dusty53
1954 Chevy 3604
It was referred to as dum-dum. From what I have found under a hinge removed for the first time, it looks and is pliable just like plumber's putty. That is what I use.
What are you working on?
Thanks all. Dusty53 I found it the same. Firm but not setup. Came off easily with mineral spirits. 52Carl, good tip on the plumbers putty. I’ll give it a try. I have a 54 GMC 100.
I would think it would be some sort of butyl tape. Something like this here
Moderator, Electrical Bay
3M 08509 Auto Bedding and Glazing compound never dries, is black and might be better than plumber's putty. I've seen plumber's putty get hard and brittle over time even though it says it doesn't.
~ Jon
AD Addict & Tinkerer
A quick Search on Amazon for” Dum-Dum putty” and I found what appears to be Dum-Dum putty and a slew of other products including butyl sealant tape that should work in your application.[LINK]
Phil
Project Journals
Stovebolt Gallery Forum
I have a large box of Perma Gum in the shop. Dad bought it in 1946. Still pliable and has been on many of my teen age projects like 29 and 42 Chevy's. Still have a lot. Thanks Dad. Doc.
Please check specs before you buy...some of the stuff on Amazon is indoor use only.
~ Jon
