8 members (3B, cshades, cmayna, Gdads51, moparguy, MickeyP, JW51, 1 invisible), 104 guests, and 3 robots.
Topics128,064
Posts1,055,861
Members48,428
#1366116 06/23/2020 6:33 PM
A few weeks ago ya'll read me moaning and groaning about leaving regular gas to long in my 54' 3100. Never again only white gas from now on. In order to avoid rebuilding the model "B" which only has 1 hour on it. I used Sea Foam at my NAPA dealers suggestion. I didn't think I used too much but the 235 chocked out and will not start. AC R45 plugs looked like fuzzy charcoal. I wire brushed and used cleaner deep down. If this does not work I have access to spark plug sand blaster. Anyone have experience with Sea Foam? Will not start engine until I hear from a Bolter. Doc
Doc.Hall #1366117 06/23/2020 6:55 PM
In my experience, Sea Foam is more suited to diesel engines. I've used it in mine a time or two. Sta-Bil is probably better for gasoline (use that in my boat).
Did you put the SeaFoam in the tank or fill the carb with it?
If you can get the engine started (wire the choke open and crank with the throttle full open), you should be fine. You'll probably rid the neighborhood of mosquitoes for a little while. grin
Doc.Hall #1366130 06/23/2020 8:36 PM
I have used Sea Foam before in the gas tank of my '48 and vintage Mercury outboards. I also put too much in the gas tank of a lawn mower and couldn't start it. I use Stabil over the winter in my boats and lawn mowers.
My favorite to use periodically in my '48 and wife's car is Chevron Techron. It's advertised as fuel injector cleaner but I think it must be good for carbs too. It's available at Costco so that's convenient. Chevron gasoline once had a good reputation because of the Techron in it.
Doc.Hall #1366135 06/23/2020 10:10 PM
Moderator, Electrical Bay
Some people love Sea Foam and other people have different ideas. I think it is about like P (T) B(arnum) Blaster, personally. Lot of sizzle and almost no steak.
~ Jon
Doc.Hall #1366149 06/24/2020 12:27 AM
I’ve used sea foam just a little here and there as well as Marvell mystery oil .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Doc.Hall #1366155 06/24/2020 1:24 AM
I'm with Wally, I like the Chevron Techron.
Jon G #1366639 06/27/2020 12:31 PM
Agree ^^^^^^^^^. As per the MSDS SEAFOAM is :
Naphtha
Pale oil
IPA ( alcohol)
So many of us use none ethanol fuel, so adding any alcohol seems anti productive ?
Some add SEAFOAM to the crankcase.......Two of those three ingredients are NOT a agood thing to mix with the oil.
Doc.Hall #1366657 06/27/2020 2:23 PM
IPA ( alcohol)
Isopropyl Alcohol (IPA)
Doc.Hall #1366842 06/28/2020 6:35 PM
I don't have an opinion about Sea Foam but MSDS isn't required to list all the ingredients. Some do some don't.
Harold Wilson
41 Chevy 3/4 Ton
Doc.Hall #1366939 06/29/2020 7:17 AM
Chevron Techron is the only product I've tried. Had no problems whatsoever.
Doc.Hall #1367016 06/29/2020 6:06 PM
Thank you all from klhasen on down. Techron is a word I have not heard in years. You folks are the best. Tonight at about 11:00 if temp is below 89 I will do what klhasen advises. Should I crank it for about 30 seconds with the plugs out? Doc.
Doc.Hall #1367138 06/30/2020 2:16 PM
I've used Sea Foam for for a long time and if used correctly it is a great product.
