7 members (55shaker, Nick in Manitou, Leo, 54farmtruck, Hotrod Lincoln, Bill Hanlon, 1 invisible), 108 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
its a manual 4 spd it has the basic 1-4 in a H pattern but when you go into neutral and slide it left and down it is reverse.
what transmission do i have??
thanks Jake.
It would be GM's own SM420 4 speed. Its a very reliable transmission that was used for almost 20 years.
thanks crenwelge for the info. i know first gear is something very low since i got 8 mpg out of first and i got to 16 in second gear
My '54 GMC 2 ton,in low in both boxes and the axle,is good for 1/2 mph at redline. ;)But,yeah-you have the SM420;I like that box a LOT better than the 435 or 465,but around here you have to fight the off-roaders for 'em.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Sm420 has the lowest 1st gear ratio of all the medium duty 4 speeds, 7.05-1. Had one in a Jeep!
You must be bored this morning. nanner
So must you!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
