Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (baldeagle, Hanks custodian, Guitplayer, Otto Skorzeny, Maybellene, Hotrod Lincoln, 1 invisible), 43 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#1364032 06/08/2020 7:02 PM
Does anyone have any pictures of a floorpan they have installed on a 47-54 3100 ? i'm having a hard time locating the door frame to the pan and holding the 331/2" opening . When i clamp it up to the notch in the pan in the rear it leaves the hole exposed in the front. It did not have a floor when i got it , so i dont have anything to refrence.
Buck.
bwilliams #1364047 06/08/2020 8:53 PM
I have some pics of my floor repairs that might help you. I did not replace the entire floor pan, but it should give you an idea of what it should look like.
I assume you're installing a complete floor pan, but don't know what you mean by the notch in the pan.
Click on the photo link in my signature and scroll thru. The floor repair photos are the most recent. If you need specific dimensions, let me know and I can measure for you.
bwilliams #1364051 06/08/2020 9:14 PM
if you can access photobucket there is pics of both sides floor pans on my 52 panel....and I think a pic or two showing them installed.
bwilliams #1364197 06/09/2020 7:44 PM
The rocker you have looks longer than the one on my floor pan. I have replaced the whole door frame . but there is a second hole in the rocker that looks like it should go behind the door post on the front. but when i align that up it wants to close my 33.5" gap .
Buck.
bwilliams #1364205 06/09/2020 8:37 PM
Buck.
Can you post a picture of your rocker? Mine does not have any holes other than the 3 in front of the front door post for the parking brake support bracket.
I would position the rocker and door post to maintain the gap.
There's a dimension in the Factory Assembly Manual (Section 1, Sheet 1.07) that shows the front end of the rocker positioned 8.47 inches behind the face of the firewall.
