0 members (),
58
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | Does anyone have any pictures of a floorpan they have installed on a 47-54 3100 ? i'm having a hard time locating the door frame to the pan and holding the 331/2" opening . When i clamp it up to the notch in the pan in the rear it leaves the hole exposed in the front. It did not have a floor when i got it , so i dont have anything to refrence.
Buck. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I have some pics of my floor repairs that might help you. I did not replace the entire floor pan, but it should give you an idea of what it should look like. I assume you're installing a complete floor pan, but don't know what you mean by the notch in the pan.
Click on the photo link in my signature and scroll thru. The floor repair photos are the most recent. If you need specific dimensions, let me know and I can measure for you.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | if you can access photobucket there is pics of both sides floor pans on my 52 panel....and I think a pic or two showing them installed. | | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | The rocker you have looks longer than the one on my floor pan. I have replaced the whole door frame . but there is a second hole in the rocker that looks like it should go behind the door post on the front. but when i align that up it wants to close my 33.5" gap .
Buck. | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | The rocker you have looks longer than the one on my floor pan. I have replaced the whole door frame . but there is a second hole in the rocker that looks like it should go behind the door post on the front. but when i align that up it wants to close my 33.5" gap .
Buck. Can you post a picture of your rocker? Mine does not have any holes other than the 3 in front of the front door post for the parking brake support bracket. I would position the rocker and door post to maintain the gap. There's a dimension in the Factory Assembly Manual (Section 1, Sheet 1.07) that shows the front end of the rocker positioned 8.47 inches behind the face of the firewall.
