4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1362568 05/29/2020 11:08 AM
Hello,
knows someone an web-side, where I can have a look of an exploded view of an 235cui engine. I want these picture, to see where the camshaft sits, to fit the fuel pump exactly.
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
https://www.chevsofthe40s.com/images_media/instructions/INS_058.pdf
Outside of the pump lever rides on the eccentric... I don't think there's any way to mix it up.
'59 Chevy Suburban, NAPCO
J Online: Content
Try these pictures , http://chevy.oldcarmanualproject.com/parts/1929_54/086.htm at the bottom is next page button. Use the Illustration section to find other pictures.
Use a bright light and a mirror to look at the camshaft lobe for the fuel pump as you turn the engine over slowly. When the cam lobe is at its lowest point, the fuel pump housing will almost, but not quite, fit flush against the engine block. There will be just a little spring tension on the lever arm all the time. IIf the lobe is at its high point, there will be a LOT of pressure against the lever arm.
Thank you for your answers, the will help.
Wolfgang
