| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Hello, knows someone an web-side, where I can have a look of an exploded view of an 235cui engine. I want these picture, to see where the camshaft sits, to fit the fuel pump exactly. Wolfgang | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Use a bright light and a mirror to look at the camshaft lobe for the fuel pump as you turn the engine over slowly. When the cam lobe is at its lowest point, the fuel pump housing will almost, but not quite, fit flush against the engine block. There will be just a little spring tension on the lever arm all the time. IIf the lobe is at its high point, there will be a LOT of pressure against the lever arm. Jerry
| | | | | Joined: Oct 2009 Posts: 171 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 171 | Thank you for your answers, the will help. Wolfgang
