| | | Forums66 Topics128,075 Posts1,055,916 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I put a ford rearend in my 46 pickup and the shifter is now on the floor. I am trying to figure out how to install the ebrake to work on the truck now and am not sure what will be the best route. I originally wanted to use the stock ebrake lever but there is not much room in these trucks to begin with and we made the floor panel. Should I stick to the plan to use the stock lever or is there a setup out there others have used.....
thanks for the help.
Charlie
1946 Chevy Pickip
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | I mounted a original lever to the side of my aftermarket automatic Lokar floor shifter. It looks original and works just as well. You can get a foot operated pedal off a late model car or truck, they are pretty easy to adapt. Joe | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I installed a Lokar foot pedal type unit in my truck. Biggest issue was routing of cables from rear wheels to pedal location - needed to miss driveshaft and exhaust pipes. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Heck, just put it in reverse and forget the e-brake. that is assuming you have a std. tranny. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Thanks for the ideas. I am going to try what Joe did first and if I don't like it I will try a foot pedal. I am installing a single lap belt in the center so i will work on that as well this weekend.
I am not sure about MI but in MA we can't pass inspection without a working ebrake....even in antique registered vehicles.
1946 Chevy Pickip
| | | | | Joined: Apr 2005 Posts: 35 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 35 | I just picked a truck with the same setup and it looks like i can use the orginal lever and rod going to the back.It looks like if i use the original ford brake cables and use 2 of the short ones it will work fine. Hope that helps.
mike | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Thanks for the info Coolie.
1946 Chevy Pickip
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Originally posted by zipper:
I am not sure about MI but in MA we can't pass inspection without a working ebrake....even in antique registered vehicles. Don't have to pass inspection where I live(thank goodness) probably coming someday. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I think I forgot to mention that I have swapped the engine/tranny with a ford 302/c4 combo so the mount for the ebrake is the issue. I will try to make a mounting bracket I guess and see if I can still use the stock lever.
1946 Chevy Pickip
| | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | Charlie,
Search the wrecking yards. Some of the old half tons had a dash mounted hand lever park brake. (horizontally operated) Same style was used on Corvairs and other budget GM's in the 60's You can also check the bigger 2.5 - 5 ton trucks for a dash mount hand lever. (vertically operated) My 78 GMC 6000 has one. Not a really popular item, so they go pretty cheap.
Jeff | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | dodge vans of the 70's used a horizontal brake lever and i used it vertically for years attached to the kick panel. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Thanks for the ideas guys...I am hoping to have time this weekend to do some more work on the truck and If the stock lever is not realistic I will be sure to look into your suggestions.
Charlie
1946 Chevy Pickip
