So I got the new water pump gasket in my '37 and it quit leaking so that's all good. A bit of trivia. I am re-upholstering the seats and found a paper tag attached to one of the springs. It says " Fort Pitt Bedding Co" and has a list of patent dates starting in 1925 and going through at least 1937. After that it gets hard to read. I wonder if they made the springs, did the upholstery or both? Use that to stump your friends who think they know everything about these trucks.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
