2 members (fonz8261, TrknGMC), 226 guests, and 4 robots.
Topics128,074
Posts1,055,999
Members48,433
#1356451 04/21/2020 7:23 PM
I have a 55 Bel Air with a 235 engine and I am removing the oil pan. I removed 11 bolts on each side but pan is stuck. Friend recommended putty knife all the way around but difficult access with no success. Any suggestions, thanks
Sean e #1356454 04/21/2020 7:37 PM
Use a Propane torch to warm up the flange and soften whatever gasket glue was used the last time the pan was installed. Obviously, clean off as much accumulated oil and grease as possible before applying heat. If you're the type of timid stovebolter who wears lace on his drawers and gets a case of the vapors at even the mention of a flame, use a heavy duty heat gun instead of a torch! I keep an air hose and a blow gun handy to blow out the fire in case I get a little over-zealous with the heat.
PSA: Saying "Bel Air" on a truck forum will get your knuckles rapped with a big crescent wrench by one of the moderators!
Sean e #1356459 04/21/2020 7:47 PM
Thanks Jerry, I was hoping I’d get a pass with the 235, thanks again.
Sean e #1356465 04/21/2020 8:14 PM
Rap rap rap.
BTW, I do report these “Car related posts” to the appropriate Moderators. Most move them to the Greasy Spoon where we have agreed they belong, but, some choose to allow this to become a all inclusive site.
eeeek
Socket Breaker
Socket Breaker
Hello Sean e, welcome to Stovebolt.com
This site is for pre-1973 Chevy/GMC trucks.
As long as you keep your posts here about the mechanical bits of the drive train that interchange with the trucks, you are fine(until the editors tell me otherwise).
If you are looking for parts, you can check out The Swap Meet section of Stovebolt.com to look at Parts for Sale or place an ad in Truck Parts Wanted.
If you need more help with the car specific Chevrolet stuff, we recommend:
https://www.chevytalk.org
https://vccachat.org
http://www.aaca.org
https://inlinersinternational.org
Thanks!
Originally Posted by Justhorsenround
Rap rap rap.
eeeek
If you have a problem with how I moderate the Engine Shop, take it up with the Editors/Owners.
They can replace me at any time, no drama on my end.
I was just helping out where needed. I'm not trying to run the place.
-Woog
Sean e #1356489 04/21/2020 10:24 PM
I used a rubber mallet to get mine off. You did remove the four 1/2 bolts in the corners, right? They are kind of hidden, especially the ones up front.
Lee
1956 Chevy 3200, 235 w/3 speed
Sean e #1356514 04/22/2020 1:18 AM
Woog deserves a raise! I recommend doubling his salary. That sounds about right. smile
I agree with helping out anyone who has a 216/235/261 no matter if it is in a car, airplane, combine, whatever (except for an F-ord, of course).
Not everyone spends regular time in the Greasy Spoon to see threads like this one.
Sean e #1356515 04/22/2020 1:22 AM
ODSS Lawman
ODSS Lawman
Carl, I'd even help a guy with a 235 in a Ford. At least they got it half right.......
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
