3 members (Joe H, Jon G, 3B), 110 guests, and 2 robots.
Topics128,092
Posts1,056,455
Members48,443
Page 1 of 2 1 2
#1338685 12/22/2019 12:51 PM
Starting a restoration of this truck after a 8 year break. Newbie to site so I don't think I can post pictures. Truck was parked on dirt floor barn since 1960 and has some rust pitting on rims, brake drums, etc. Fairly new to restoration work so tips and advice appreciated. Past restoration projects 1917 Dodge Brothers Roadster and 68 MG Midget. This is my first stovebolt build. I'll try to address things on at a time.
Truck has been disassembled and stored undercover. Frame has been sand blasted and epoxy primed. New spring pins and shackle bolts installed.
Disassembled transmission yesterday and started cleaning. Everything shifted ok but stiff before disassembly. No rust and everything coated in very thick tar like grease.Gears and bearing seem ok.
Anything I should be looking at in transmission before reassembly?
37 Chevy 1.5 ton
23 Dodge Brothers Touring
23 Dodge Brothers Coupe
73 Plymouth Scamp 2 dr
back yard wrench turner
Yea, another stake body truck on the stovebolt.
You are lucky to be able to restore your driveline. Mine was full of water and locked up tight.
I'll be following your progress.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
John, read the photo instructions in the left margin of every page. Give it a try. I don’t believe you are restricted from photos . But, I’ve been wrong before.
Welcome to the 'bolt. There is a welcome forum that you can check into as well. have fun.
Another quality post.
Real Trucks Rattle
I thought I had to post 5 times before I could post pics. Didn't work on truck today. Hopefully tomorrow back to transmission.
37 Chevy 1.5 ton
John,
Regarding the transmission, if the gears and bearings look good, you have a great start. That tranny (GTK-134) has no synchros so if the gear teeth are not obviously worn that is a good sign that it was used by someone who knew how to shift. Check the external case for broken mounting ears (the two at the top). While I am thinking about mounting the tranny, the bottom two bolts mount into the case so be sure to use sealant on the threads on assembly or you will end up with a slow drip.
The bosses cast into the case to mount the parking brake and pedal assembly also need to be examined. They are tapped for the mounting bolts but bottom out. If you use too long of bolts you will break off the bosses. So be sure someone else has not broken them and be sure your mounting bolts are not overly long.
Get your self an repair manual or look up on line (Old Online Chevy Manual, Keith Hardy's site). The only measurement necessary to reassemble is the gap between the cluster gear and case (0.015 to 0.045 inch, I think going on memory). If you decide to disassemble the shift tower, you can put sealant on the ends of the shift rails, another place these trannys leak oil.
Good luck and let us know how it is going,
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Thanks for the info Kent. Will look at all suggestions a was hopefully today and post.
Manuals I have
Master parts list 29-47 and 29-48
Motors truck manual 1936-42
Happy Holidays, John
37 Chevy 1.5 ton
Here's some pic I hope
37 Chevy 1.5 ton
Going to work on drive line first so I will post progress there
37 Chevy 1.5 ton
Finished transmission yesterday. Started rear end
37 Chevy 1.5 ton
Awesome! Great project you have there!
John, I have the exact same truck. Same color and looks to be in about the same condition. It was my wife's grandfather's farm truck. It was parked in the barn in 63 and didn't move until I pulled it out last August. I've got it completely down to the frame now. I've attached a couple of before and after pics of the engine and transmission rebuild. I sent it out to a guy. Good luck on your project.
Progress being made. Engine and transmission are back in truck. Still waiting on radiator and generator before start up so switched to body work. Sandblasted, repaired, and painted radiator support and front fender skirt. Removed cab parts and seat support/floor to prep for welding and paint.
37 Chevy 1.5 ton
Hi Dennis, good to hear from you. Would love to see pics of your cab if you have any available
37 Chevy 1.5 ton
Here are some photos of the cab. The only real rust issue I have is the lower rear panel of the cab.
Much better shape than mine. Front and rear cab corners are pretty much gone. Finished welding cab corner supports today. They were all broken and shattered. Before my truck was retired they used it as a self unloading wagon for corn silage. I think it was also hit pretty hard in rear center of cab. Thinking of putting an extra strip of metal to smooth out where dents were on rear of seat support. Debating on whether to repair corners before or after sandblasting. I'm thinking after . That way I don't have to move to sandblaster a few miles away with new sheet metal andd chance damage.[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/16838/filename/IMG_1579.JPG[/img][img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/16836/filename/IMG_1853.JPG[/img]
37 Chevy 1.5 ton
Some more pics
37 Chevy 1.5 ton
Nice.
Maybe you have already considered that blasting will find holes you missed the first time around. It's your truck, do as you wish.
Still nice!
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Yes i'm sure more will materialize. I
37 Chevy 1.5 ton
Started fabricating front cab corners. Dennis, I see in your picture there is a bead rolled section at bottom of front post near door. Could you possibly do a close up pic of that section? Also sent you a PM.
37 Chevy 1.5 ton
Absolutely ZERO promises but if you PM me a list of parts you need I might be able to find a few since the only thing we kept off a 37 stake bed we modified was the body sheet metal. May (?) have chassis down at storage yard and put smaller pieces into two storage buildings nine years ago so might be as easy to find as Unicorns. Would not look for any but if I know what you need I would set aside as I stumble across them. Do remember it had a perfect windshield crank out assembly which is rare. Pics show little original parts remain. Has a rollback bed now that owner uses to haul his 37 Chevy Business Coupe.
[img]https://i.postimg.cc/xNCRc9J2/37-Hauler-Don-s-for-sale-86-007.jpg[/img]
[img]https://i.postimg.cc/z34k7Z4x/37-Hauler-Don-s-for-sale-86-005.jpg[/img]
[img]https://i.postimg.cc/D8gc1j3Z/37-T-wide-fenders-006.jpg[/img]
Evan
Pm sent. Here's some pics of work over last few days on cab. Still waiting for good weather for sandblasting
37 Chevy 1.5 ton
One more pic.
37 Chevy 1.5 ton
Off to sandblast cab today
37 Chevy 1.5 ton
Took me a second to realize what was going on in that second photo! dang
Looks like you're making good progress.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Looks like your a vintage dodge fan. Shhhh
I have a few.
Reworked an old repair on dash to steering column support today.
37 Chevy 1.5 ton
Sweet!!
Mac :{)
Starting to work on 37 truck again. Fixed supports for lower firewall and sheet metal yesterday. Bought a new floor pan from the filling station and noticed one cutout is different. Anyone know how original Wiring was done or have pics. Wiring was a rats nest when I bought truck and
Would like to put back To original. Sharpie is pointing at cutout on right in question. Thanks, John
37 Chevy 1.5 ton
Is that cutout directly over the Master Cylinder?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Bingo. I guess it’s been apart so long I’ve forgot where things go. Thanks
37 Chevy 1.5 ton
Regarding the wiring, I did a body off restoration on my '37 1/2 pick up. The truck came in pieces with almost no residual wiring. I ordered a complete wiring harness from Rhode Island Wiring and figured out where things go by deduction. I think I can help you with pictures which would be best by email; my email address should be in my profile. For the next week I am not where my truck lives so if you are patient I may be able to help.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Thanks Kent. Still working on sheet metal so there’s lots of time. I’ll pm you with my contact info
37 Chevy 1.5 ton
37 Chevy 1.5 ton
AD Addict & Tinkerer
I just started following you project. Your doing some nice work and making headway. Keep up the good work and before you know it you’ll see that light at the end of the tunnel. If your like me, I enjoy the journey and satisfaction of the little victory’s along the road!
Phil
Project Journals
One step at a time.
Here’s some more photos
Had to make these parts for my passenger door
37 Chevy 1.5 ton
John, this brings back memories from when I did the same to my '38.
Great work!
Wayne
1989 Silverado
Doors are in epoxy primer and ordered glass channel kit and a few other parts.
There wasn’t much left to the old widow wiper seals or glass channel. Piece pictured of channel was all that was left from 2 doors.
I’m assuming channel runs AllThe way around from one side to the other.
One of my doors had what looks like a track for window channel on hinge side and other door it was missing?
Is the piece that’s there complete? Going to make on for other side but not sure if I’m missing part of it.
Contemplating my next step. Running boards? Tin around nose and radiator? Both are really rough and will probably try to make new.
Any thoughts
37 Chevy 1.5 ton
Not real sure from your pictures what your question is about the window channel, but I believe it runs only on the sides (2 pieces per door) and not across the top. As I recall if you run the channel as one piece across the top of the window it would cover part of the garnish molding. The top of the glass with the window all the way up is tucked up high enough in the door that you don't get wind noise while driving.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
[img]https://www.stovebolt.com/ubbthread...49CA4E5-CA18-4FCC-AF07-35FA2E95AC88.jpeg[/img][img]https://www.stovebolt.com/ubbthread...49CA4E5-CA18-4FCC-AF07-35FA2E95AC88.jpeg[/img]Thanks for your Input Kent. Here’s another picture. The part that’s circled in yellow is what I’m not sure about. End looks ragged. Wondering it’s purpose and if it should be longer.
37 Chevy 1.5 ton
Page 1 of 2 1 2
