0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | Looking for new front springs for my 1950 1 ton. Called a few places and they all seem to have no problem coming up with 1/2 ton & 3/4 ton springs, but not the 1 ton. Just wondering if anyone has an idea where to go for these. I live in Minneapolis so a place close to home would be nice, but I will go where I can find them. New U-bolts would also be needed i'm sure. Any suggestions are appreciated. Thanks, Tom | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | A spring shop will make a new leaf or the whole stack from scratch A place just 40 min from me said they prefer to work from a pattern seeing the original one to get the knuckles just right but could also work with just a description and measurements. This same place informed me that the front springs for the 1 ton are no longer a stocked/order-able part in North America I suspect pretty much all shops have the same few suppliers and if their catalogs don’t list it anymore it can’t be ordered So our only choices are, get one made, find one in a junk yard, hack a home made solution from some other spring that is close enough to work... but I don’t know about that last one as I’ve never found a suitable replacement.
If anyone has more insight for this spring please let us know Because I’m gonna need a couple more soon as well. But I’m happy getting new ones made because the price I was quoted seemed reasonable. Thanks -Stan | | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | Thanks Stan, i will star looking for a shop somewhere that may be able to make them. I did see Eaton Detroit Spring shows on the website they can make them. Has anyone purchased from them in the past and are their products good? Their description however for the right year and model list 9 leaves in the spring pack, my truck only has 7 leaves in the front springs. Too bad these are no longer available from most places now that I need them. The hunt will continue. Tom | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | The 1/2-ton and 3/4-ton front springs are the same, and yes they are available nearly everywhere. I agree with the others that you should be able to have them custom made. As far as I know Eaton Detroit has a good reputation. But there might be a local shop, probably in Minneapolis that does that.
Professional Novice
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | You could probably use the narrower 1/2 or 3/4 ton front springs with spacers on the 1 ton If you don’t intend on using it to the full weight capacity It should work right? The front end of the 3/4 ton is likely the same weight as a 1 ton, everything is the same above the axle pretty much. -s | | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | St Louis Spring. www.stlouisspring.com They blow Eaton Detroit away on pricing and they're US made with Canadian steel. They can make anything you want. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I prefer Eaton Detroit Springs for spring sets, and I once used ESPO Springs & Things for shackle assemblies - a third good company to consider/compare. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I used City Spring in Edmonton. I got a copy of the original spec sheets for my 1 tons front springs and they whipped me up a set in a couple days. I think the closest one to you, though, would be in Regina, Saskatchewan. Might be cheaper than US made? Our dollar is pretty low right now vs US dollar. $1 vs $1.35 ish. | | | | | Joined: Nov 2012 Posts: 6 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 6 | I also used St. Louis Spring company for new springs on my 1950 3800. They made them in 24 hours, and luckily, I live 2 hours away and was able to pick them up the next day. I also got a tour of their shop - super nice folks. They supply Jim Carter's as well. Highly recommend them!
| | | | | Joined: Aug 2001 Posts: 3,598 Moderator | | Moderator Joined: Aug 2001 Posts: 3,598 | I have also heard many good things about St. Louis Spring. Been open since 1945. But they are located in the more, let's say, questionable area of St. Louis? So you have to call before you go to pick up during the daytime.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | Thank you to everyone for all the quick responses, I will get this project going soon, winter is gone from the Twin Cities ( I hope) so it's truck driving time. Also have new shocks waiting to be installed. i will check with all places listed above, see where my best deal is. If anyone can think of anything else that may be beneficial to this project, please join in. Thanks again, Tom | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Has anyone tried having existing springs re-arched? If the leaves aren't too worn I would hope that could work. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I have no personal experience, but I know it has been done, and there are shops that can/will do it. I have read similar discussions on the HAMB and other boards. The shop may prefer to sell you new springs instead of re-arching yours. And that might be the more economical choice.
Professional Novice
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've heard it said, but no documentation, that re-arched springs to not hold up well for long period of time..... but of course companys want to sell you shelf of regular production stuff........just saying. | | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | I've heard it said, but no documentation, that re-arched springs to not hold up well for long period of time..... but of course companys want to sell you shelf of regular production stuff........just saying. No reason why re-arched springs would perform any differently than original. The metallurgy isn't changed. They did get into the yield range when re-arched, but not enough to affect the fatigue life of the base metal. If they were re-arched multiple times (like 100), then it might be a different story. That statement is a marketing ploy, IMO.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | I ended up ordering new springs from St. Louis Spring. I ordered them this past Monday, got a call from them on Wednesday saying they were ready to ship, they arrived just an hour or so at my house. Look great, the guys I talked with were very helpful in determining the exact spring for the vehicle. Came with new bushings in the spring eye's, all nicely painted, cant wait to get them in the truck. Maybe I did too much worrying about where to get new springs when I started this post just 8 days ago, but just like that I have new front springs for my 1950 1 ton. Thanks to all of you for your advice and recommendations. Everyone have a safe and healthy weekend. Tom | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Excellent! It feels great, doesn’t it? I love bolting on new parts. That’s a LOT of fun. | | | | | Joined: Apr 2020 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 87 | Thats the way i do it (new springs)! Cost is about the same figureing time, even if i do it my self!
Karl j Townsend
| | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | I used St Louis Spring for my 50 and they're the best. The shipped to NC and answered my questions a year later.
1950 GMC 250 Pickup 1965 Mustang Convertible 1972 K5 Blazer 1973 Buick Centurion 455 Convertible
| | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | This good news! Yesterday, I ordered front and rear springs for the '47 from the St. Louis Spring Company. The owners are very knowledgeable, very happy to answer questions and make recommendations.  | | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | I'd consider replacing the Shackle bushings as well. RockAuto has them, I put the bushings in the freezer overnight and the cleaned up shackle in the oven at 350 for 30m. The bushings slipped in with minimal encouragement.
| | | | | Joined: May 2020 Posts: 1 Moderated | | Moderated Joined: May 2020 Posts: 1 | Did you have trouble removing shackle bushings? I have already replaced rear shackle bushings but seems the front ones are being more difficult. Any suggestions? | | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | Did you have trouble removing shackle bushings? I have already replaced rear shackle bushings but seems the front ones are being more difficult. Any suggestions? What truck are you working on? I've used the method recommended by Pre '68 Dave and it's never failed me. CLICK: Spring Shackle Bushing Replacement | | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 | I used Pre ‘68 Dave’s method on my spring bushings and it worked perfectly.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | Replacing the leaf spring and shackle bushings on my 1T was a real PIA. Its not so much getting the bushing out of the shackle, but more getting the 7/8" stainless pin out from where it has resided for 70 years. Once out, I used a hack saw blade to cut the bushing in half. Dave's method should work as well.
| | | | | Joined: Dec 2002 Posts: 22 New Guy | | New Guy Joined: Dec 2002 Posts: 22 | I have a 1953 3600 that I will be updating and converting to 4WD. This will be my 3rd 2WD to 4WD conversion.....but 1st conversion on an advance design truck. I will not be using NAPCO parts. I am considering installing 2" wide 3800 front springs in my 3600 to handle the additional weight of the drivetrain and to better fit the 4WD axle. Is it possible to install the wider and longer 3800 springs on a 3600? Are the 2" shackles and spring hangers available? Are the rear hangers in a different location to accommodate the longer 3800 spring. Or alternately, I could have 2" wide springs made by St. Louis Spring Company to match the length of the 3600 springs. Thanks for the help.
1953 Chevy 3600 1998 Dodge 2500 Cummins 12 valve
