1 members (moparguy),
39
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '56 has a 350 engine with Edelbrock carb. I need to put a kit in it but don't know how to ID the carb. Can't find a tag. Do I need to know what it is or are the kits all the same?
If I do need to ID it where do I look? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I don't know how to ID an Edelbrock, but I'll give you my "this is what I would do" advice. I would get an old Quadrajet from a 350ci GM and rekit it. Quad's have their number stamped on the side so you can get a kit everytime it needs it. I'm just a little partial to the Quad since they adjust and rebuild so easy.
Nice meeting you last week-end too! Scott | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | The number should be stamped in the base flange on the front of the carb. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks chuckthetruck. I had tried to ID it by that number on google but it turned up nothing. I finally figured out just use the first 4 digits.
Scott, thanks for the suggestion. I have a Q-jet from my '83 Jimmy I forgot to take back for my core deposit in time. After seeing the price of an Edelbrock kit, I'm considering it. I don't suppose you know if it needs an adapter to fit an Edelbrock manifold, do you? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Cletis, If you rebuild the Q-jet you might want to pick up the book Carbking recommended "How to Rebuild and Modify Rochester Quadrajet Carburetors" by Cliff Ruggles. Excellent book the guy really knows what he is talking about. The book will tell you how to setup the Jimmy carb for your 56.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The Edelbrock carb is basically a Carter AFB. They are easy to rebuild & drive real good. The gas mileage is not as good as the Q-jet. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Originally posted by Wrenchbender Ret.: The Edelbrock carb is basically a Carter AFB. Will Carter would not like to read the above. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2006 Posts: 5 Junior Member | | Junior Member Joined: Nov 2006 Posts: 5 | INSTALLING A QUARAJUNK ON YOUR ELDEBROCK MANIFOLD WILL REQUIRE AN ADAPTER. (GREATLY KNOWN FOR ADDITIONAL VACUUM LEAKS)SECONDLY THE Q-JET IS CONSIDERABLY MORE COMPLICATED TO REBUILD AND TUNE. PRICE OF ADAPTER + Q-JET KIT COMPARED TO EDELBROCK CARB KIT???? | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I think the Quadrajets are a pretty good carb. The thing that screws them up the most is that the shafts wear into the housings and the housings need to be rebushed with a kit. Without it they are mostlikely be a poor performer and have dead spots through the rpm range. If you can't tune a Carter AFB, you might not be able to tune an Edelbrock. Bolting them on is not tuning. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Cletis, Should be a 4 digit number on the left front flange right where it bolts to the manifold. My 600 cfm says 1479. I have a list of the Edelbrock numbers.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Q-jets also wear out the secondary metering jets.These are not replacable so if they are oblong the carb is junk.Also look for worn metering rods.This carb is very tuneable and can be mounted to Edelbrock intake.I have a Perfomer and it is a direct bolt on.Good Luck
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Thanks for all the repies. I rebuilt and rejetted my Edelbrock 1406. It runs great. Here's the post about it. | | |
