| | | Forums66 Topics128,080 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | Ok so i lowered my 64 chevy 1/2 short fleet like 6 months ago. I put 3" drop coils in front and 4" drop coils for rear. So the rear is higher than front. I just ordered 6" drop coils for the rear cause i want it to be lowered and i dont have to c-notch it cause it will still have almost 3" of clearance as long as i do not load the crap out of it... anywasy do you think with the 3/6" drop that i will even out the truck or will the rear be lower than the front?
Stovebolt-It is painted
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | It's easy enough to measure. Get out the trusty tape measure check things. I have no idea off the top of my head of that will sit even. Good luck.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You can always put a load assist airbag set-up in there to help "adjust" the ride height. I think JC Whitney sells them fairly reasonably. I like that idea because it goes in with your suspension rather than instead of your suspension, Scott | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | thanks..i think it should be fine..i ordered them from early classic enterprise in fresno. They said that it should be leveled out as if emptied..aslo i wont be c-notchin it they said its not recommend unless i plan on loadin my truck and im not..
