4 members (farmallb, Gib70, Gdads51, Nick in Manitou), 132 guests, and 3 robots.
Topics128,088
Posts1,055,998
Members48,430
#134864 07/22/2006 6:44 PM
Ok so i lowered my 64 chevy 1/2 short fleet like 6 months ago. I put 3" drop coils in front and 4" drop coils for rear. So the rear is higher than front. I just ordered 6" drop coils for the rear cause i want it to be lowered and i dont have to c-notch it cause it will still have almost 3" of clearance as long as i do not load the crap out of it... anywasy do you think with the 3/6" drop that i will even out the truck or will the rear be lower than the front?
Stovebolt-It is painted
#134865 07/22/2006 7:30 PM
It's easy enough to measure. Get out the trusty tape measure check things. I have no idea off the top of my head of that will sit even. Good luck.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#134866 07/22/2006 8:26 PM
You can always put a load assist airbag set-up in there to help "adjust" the ride height. I think JC Whitney sells them fairly reasonably. I like that idea because it goes in with your suspension rather than instead of your suspension,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#134867 07/23/2006 12:21 AM
thanks..i think it should be fine..i ordered them from early classic enterprise in fresno. They said that it should be leveled out as if emptied..aslo i wont be c-notchin it they said its not recommend unless i plan on loadin my truck and im not..
